It is currently Tue Nov 17, 2026 2:43 pm
 Post subject: Ball and Ball carb
PostPosted: Thu Jun 18, 2009 8:27 pm
I have a 65 valiant wagon with a 225. It has a single bbl Ball and Ball carb on it and I cant find any info on the BandB except that is was made for Chrysler. Any one have a link to site about these things?
Thanks
The only number on the carb I could find was 1695
Dont know if that will mean any thing to anyone.
This is my Signature
Russ Stanley
PostPosted: Thu Jun 18, 2009 9:12 pm
Welcome on the board. Your carburetor is a 1-barrel Carter BBS (= Ball and Ball, Single). Carburetor operation and repair manuals (and some training movies) are posted here for free download. 1695 is a casting number, and doesn't identify the carburetor. The carburetor number would have been on an aluminum tag secured to the carburetor by one of the two front bowl screws.
PostPosted: Fri Jun 19, 2009 10:25 am
Thanks Dan
After pulling the carb I have more problems than I thought.
I was going to do a rebuild and call it good. No such luck. I need a new carb.
The air horn base is warped. After cleaning and replacing parts with the kit for that carb I found that the it is warped . So bad in fact that I can see daylight through the front of the body.
Any sugestiond for a new carb? I wou;d like to stay with a 1 bbl. I checked Holley and I cant find 1 bbl on there web site.
Thanks
BTW
After pulling the carb and cleraning it I found the Carter name on it.
Russ Stanley
 Post subject: Never knew that!
PostPosted: Fri Jun 19, 2009 5:41 pm
I always thought bb was some strange symbol for 'barrel' :oops:
I have a ball and ball carb on my b model pickup with flathead 230 dodge engine- had to rebuild the acc. pump with hand made leather parts. Maybe I should have just re-used my old slant carb!
Thanks Dan!
madam im adam
PostPosted: Fri Jun 19, 2009 7:18 pm
BBS BBD bbl
PostPosted: Fri Jun 19, 2009 8:25 pm
I need a new carb.
All the BBD's are that way too. I run them on a belt sander to flatten them.
I try and collect all the BBD's I can. I am going to start collecting the BBS's.
Come to thing of it :roll: I'll collect anything that says CARTER on it!
PostPosted: Fri Jun 19, 2009 10:01 pm
........Come to thing of it :roll: I'll collect anything that says CARTER on it!
USELESS INFORMATION ...... I have a friend who runs a carburettor repair shop,and his shop CAT is named ... yep.... CARTER.
(told you it was useless info)
regards,Rod :D
PostPosted: Sun Jun 21, 2009 4:25 pm
http://cgi.ebay.com/ebaymotors/DODGE-PL ... 240%3A1318
PostPosted: Sun Jun 21, 2009 5:24 pm
1. Link doesn't work.
2. We don't post eBay's long garbage-filled URLs here. Please post eBay links in accord with directions in this post.
Thanks!
PostPosted: Mon Jul 27, 2009 11:37 am
What other single bbl carbs can i use with my existing intake manifold. I am having a hard time finding the info I need.
Thanks
Russ Stanley
PostPosted: Mon Jul 27, 2009 12:37 pm
A Carter BBS or a 1920 Holley.
PostPosted: Mon Jul 27, 2009 12:51 pm
Thanks
There is a member on here that has a 1920 he will sell me.
Russ Stanley
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 7 guests
