It is currently Fri Nov 20, 2026 2:55 am
 Post subject: dakota manual
PostPosted: Thu Aug 06, 2009 7:22 pm
found a good deal on a mid 90s 2wd manual dakota trans and rear.....will and how can i put this behind my six?...........sorry about the typing problems...im using my phone haha
78 Aspen
Lookn' to enjoy it.....lost in logistics
PostPosted: Thu Aug 06, 2009 7:30 pm
Do you really want a 4:1-ish 1st gear and wheels that stick out about 8" per side?
PostPosted: Thu Aug 06, 2009 9:40 pm
a Dakota rear won't stick out that bad; the bigger pitfall is if it is newer than 90, it will have 6 lug axles.
PostPosted: Thu Aug 06, 2009 10:30 pm
nothing is impossible.....axel swaps can fix the six lug issue and if u know anything about aspens (and you wouldnt be here if u didnt) you know how far under the car the wheels are....anyway theres also an auto.....dunno if its two wheel drive though... anyway the teardown is comming soon and im brainstorming.... im headed into powertrains class...maybe ill get a chance to regear it too.
78 Aspen
PostPosted: Fri Aug 07, 2009 10:11 am
no mre late night replies for me....i forget what im typing....anybody sell adaptors?
78 Aspen
PostPosted: Sat Aug 08, 2009 3:29 am
No, but you can put the 5-lug Dakota axles in the '96 and older 6-lug housing.
PostPosted: Mon Aug 10, 2009 11:32 pm
ok...talked to lot-o-shops...nobody knows if u can regear it...oh well...theres always an auto....maybe ill still get it and put it in my truck..thanks for all the answers
still gonna get the rear though...cant pass up bettier gearing
although i might have a shure grip....i dunno....im getting more on the plate everyday....
now where did i put my lotto ticket?
78 Aspen
PostPosted: Mon Aug 17, 2009 8:07 pm
Forum member sixinthehead has done this swap.
http://www.slantsix.org/forum/viewtopic.php?t=10197
 Post subject: trans and diff swap
PostPosted: Tue Aug 25, 2009 10:41 am
I just completed a simular swap into a Plymouth Caravelle (1978) This is the same platform as the aspen.
I put an 89 dakota sport 3:91 posi,1975 3peed OD( heavy case) behind my slant. Works well after I corrected the pinion angle.
I still have a vibration when I push in the clutch. I'm pretty sure it's the clutch brg.
Good luck.
Users browsing this forum: Google [Bot] and 7 guests
