It is currently Sun Nov 22, 2026 11:38 am
 Post subject: cap over thrust bearing
PostPosted: Sun May 11, 2003 10:56 pm
Any tips to remove this sucker? The others I could wiggle off but the thrust bearing doesn't leave much room for any wigglin ;)
PostPosted: Mon May 12, 2003 12:28 am
To get the #3 main bearing insert out of the cap, place something narrow and blunt on the edge opposit the tab then tap the insert edge to slide it around. Once the other side pops-up about 1/2 inch, you can push it away from the cap.
PostPosted: Mon May 12, 2003 12:47 am
Erp doc sorry I should have been more clear. I can't get the cap itself off of the block.
PostPosted: Mon May 12, 2003 5:13 am
Pull the bolts up in the cap and tap them side to side with a plastic hammer. The cap will pop loose and work out. :shock:
Users browsing this forum: Amazon [Bot] and 12 guests
