It is currently Sat Nov 14, 2026 2:54 am
Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4
PostPosted: Fri Aug 07, 2009 4:27 pm
just a heads up...went to the auto parts store to price the water tight conecters for the HEI coil...50 bucks and some change..if you find one grab it....and put it with the rest of the I"LL NEED IT LATER stuf in the shop... :idea: or send it to me, I'm still looking
Its so nice out side, I think I'll go lay under my car..
PostPosted: Mon Aug 10, 2009 4:12 pm
Wow what a difference... I had problems before the switch when I would drive cold. With the HEI cold driving is a problem no longer. And to top it off I still havent gaped the plugs any wider yet....
This is a swap worth doing.Thanks for the advice and info Slant Forum!! :D
PostPosted: Mon Aug 24, 2009 9:40 am
I just got back from the local yard and I found the heat sink and a coil. My question is will a coil from a 93 silverado work with this conversion it only has two wires going to the coil so I am thinking that this will work. I am planning on buying a 73 ING control module Thanks for any advice on this. Thanks have a Great Day! JIM
1956 Dodge D100 Pick up
power plant 225 slant six
