It is currently Thu Nov 12, 2026 3:01 am
 Post subject: Odd timing behavior
PostPosted: Mon Aug 10, 2009 8:48 am
I have my super six conversion installed now and I'm working on dialing it all in. Last night I went through about half a tank of gas doing a 2 mile loop over and over with different timing settings trying to learn what works best on my engine. I tried everything from 20 degrees btdc all the way to 6 degrees after tdc. The odd thing is that the more retarded I have it set, the better the torque I'm getting. With it advanced even a little, I am getting a kind of rumbling growl but very little acceleration when I floor it. However when it's retarded to 6 degrees after tdc, it actually seems to accelerate better with no rumble. Of course then it has problems while cruising.
I'm using a stock engine build, slant six 225 on a 63 valiant with a 3 speed manual tranny. It has the Carter BBD on it which was just rebuilt. I think it has the stock jets in it 120-386. The only other thing I've messed with a bit is the metering rod height.
One more odd thing that happens is that when I have the vacuum advance connected to the distributor, the timing mark actually retards before advancing when I give it some throttle. I didn't think this was possible. I know the vacuum canister works because I hooked up a vacuum pump to it and it advances the timing properly. The mechanical advance also works fine.
Any ideas?
PostPosted: Mon Aug 10, 2009 2:44 pm
It would have been nice to of degreed the cam. Sounds like a tooth off but I hope not. Maybe just a tooth off on the distributor.
PostPosted: Mon Aug 10, 2009 5:03 pm
Site Admin
At idle, when you disconnect your vacuum advance, does the timing retard?
Restab the distributor, then re-time it. It sounds like your off a tooth there like Ted suggested. Your vacuum advance can should do nothing at idle. You probably can't get the timing where it belongs, and have to compensate with a wider throttle plate opening. The plate should mask the ported vacuum.
If your cam timing is off, the front of the engine needs to come off again.
CJ
Users browsing this forum: MadScientistMatt and 3 guests
