It is currently Wed May 20, 2026 1:21 pm
PostPosted: Mon Aug 10, 2009 6:38 pm
Car Model: 1962 Dodge Lancer GT Black/Red
Hey Dan,
Are you familiar with the power steering gear on a '61 Valiant.
I believe it's a rare combination.
The one I have has an amazing amount of free-play. Do you have info on how to repair / replace this? Is it so rare or desirable that it would be wrong to consider replacing with a newer K-member?
Thx in advance, Ray
PostPosted: Tue Aug 11, 2009 8:57 am
I do welcome any info I can get regarding this topic. thx,Ray
PostPosted: Tue Aug 11, 2009 7:25 pm
It is most likely a rare option-- although all 1961 valiant items are rare today. Not sure where ssDan is to give you facts/figures.-- It has been discussed swapping newer 62-66 k members for the odd 60-61 style-- no one has done it (that I recall)
you might see if you can find a manual gear/ column & swap them out --. Good luck-- Lawrence
PostPosted: Wed Aug 12, 2009 11:36 am
Is there an advantage to going manual aside from parts availbility?
Does anyone know if the newer k-members will bolt onto the 61 Val?
Thx, Ray
PostPosted: Sun Aug 16, 2009 1:19 pm
I put a 65 kmem in my 61. I also changed the a arms, lower control arms, ball joints, strut rods and the steering gear. I was after disc brakes.
So my 61 basically now has a 65 suspension with a 70 disc setup. The steering gear mounts on the kmem in 62-66, not to the left frame like 61. I am not sure if the 61 lower control arms will work with the 62-66 kmem. And if you change the lower control arms, the strut rods change due to mounting differences.
Another disclaimer - I have not had my 61 out on the road since the swap
- they may be problems I have not encountered yet - but it all appears okay. I do have two well used manual steering boxes from 61 valiants hat I no longer need.
 Post subject: Thank you Relic Lover
PostPosted: Sun Aug 16, 2009 4:27 pm
That opens up many new options. Please keep me posted. Ray
PostPosted: Tue Aug 25, 2009 5:35 pm
have you made any decisions on the p/s ? I believe the manual steering has a 20:1 ratio-- which seems to be a good choice for these cars. You would need a manual column thogh, L
