It is currently Mon Nov 16, 2026 3:05 am
 Post subject: V8 swap?
PostPosted: Sun Aug 09, 2009 10:41 am
Ok i know this is blasphemy.. But what all parts will i need to change a 64 dart with a 3 speed to a318? I already got the correct bell housing!
PostPosted: Sun Aug 09, 2009 12:50 pm
I think you just need V-8 brackets for those. Very hard to come by. Wasn't Schumacher or somebody making those? Good luck with your exhaust. Oh yeah, and I think the distributor gets in the way of the firewall where the wiper motor mounts. The z-bar will prolly be too wide, but you should be able to cut yours down to make it fit. I'm not too sure on the release fork.
I have an old article from a mopar swap compilation book somewhere. Let me look around. I can scan it and email you the pages if you like.
What are your plans for the slant stuff you'll have left over?
-James
PostPosted: Sun Aug 09, 2009 3:53 pm
you may want to visit
www.forabodiesonly.com
and post there..
or jam up to a BB
www.BigBlockDart.com
PostPosted: Mon Aug 10, 2009 5:43 am
1964 was the first year for the 273.
For a 273 or 318.
You will need a set of V8 motor mounts, a V8 center link, a V8 radiator and 273 exhaust manifolds. If you have the 9" brakes you should upgrade to at least the 10" brakes.
For a 340 or 360.
You will need all of the above plus you need to modify the motor mounts to work. Also you should use a set of disk brakes and tie the front and rear sub-frames together with sub-frame connectors.
PostPosted: Mon Aug 10, 2009 9:48 am
For a 273 or 318.
For a 340 or 360.
Also if you go to a 360 (which is externally balanced)- You will need a 360 specific oil pan (because of it's different rear main seal size), weighted flexplate or 360 specific converter. B&m, makes a flexplate that will allow you to use the 360/904 combination.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Mon Aug 10, 2009 10:02 am
Any good running V-8 making decent power / torque will blow-up that 3-speed and the 7 1/4 rear-end in a jiffy so put an 833 4-speed and a 8. X/x rearend on your list.
PostPosted: Mon Aug 10, 2009 12:19 pm
look here
PostPosted: Tue Aug 11, 2009 8:19 am
so i wont have to change the steering column or the throttle inkage?
PostPosted: Tue Aug 11, 2009 8:54 am
Steering column, no change if you use the 273 exhaust manifolds. (yuck)
Throttle linkage will have to change to the cable type.
PostPosted: Tue Aug 11, 2009 10:35 pm
Here's a little tidbit. If you can afford the 340 A-body exhaust manifolds and you have manual steering, A little grinding on the driver side outlet and they slide right in. I did this trick 30 some years ago when they were throwing them away. A nice alternative to fender well headers.
PostPosted: Wed Aug 12, 2009 10:33 am
thank you very much guys! this wont take place for awhile now..but when i do ill have some extra slant parts...i know ill have an electronic ignition up for grabs
PostPosted: Thu Aug 13, 2009 6:05 am
I think you can use the Magnum truck manifolds on the early A's.
PostPosted: Thu Aug 13, 2009 7:42 am
I was thinking that the left side wont work/clear :?:
PostPosted: Thu Aug 13, 2009 9:07 am
I swear on FABO they had pics and everything! Takes some grinding and maybe shimming the mount IIRC.
