It is currently Tue May 12, 2026 9:32 pm
PostPosted: Tue Aug 11, 2009 11:59 am
is this swap possible? if so what parts are needed? thanks for the help
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
PostPosted: Tue Aug 11, 2009 12:22 pm
Reuse your UCA. You'll need the 73-76 steering knuckle and if available the dust shield. I'd go with new rotors, bearings, calipers and hoses - all readily available new. I did the swap on a 69 Charger and 65 Coronet 440 and works like a charm.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Tue Aug 11, 2009 1:21 pm
thanks for the help. i am also doing this swap on a 65 coronet 440. post so pictures when done
PostPosted: Wed Aug 12, 2009 8:43 pm
The late model A body stuff will bolt right onto an early B body car. You can run the caliper in front of the knuckle (recommended) or to the rear. If you have an aftermarket anti-sway bar you might need to spend some time to get everything to play together.
I wrote a magazine article on this exact swap years ago. Do a Google search on my name and you'll find it.
Andy Finkbeiner
