It is currently Fri Nov 13, 2026 5:21 am
Post new topic  Reply to topic  [ 101 posts ]  Go to page Previous 1 2 3 4 5 … 7 Next
PostPosted: Tue Aug 11, 2009 2:43 pm
I was just looking at that 320 HP article. That thing sounds awesome but 13.5:1 compression is pretty wild. Wonder what kind of fuel they used.
I would like to know what maximum compression could be used with pump gas. Does altitude make a difference?
I think from reading this article that 280-290 HP NA on pump gas ought to be doable.
PostPosted: Tue Aug 11, 2009 2:55 pm
I think if you put in a bone stock /6 and then put a bunch of performance stickers all over the car you will way over 300 HP :lol:
Raymond Flynn
Registered Six Offender!!!!
PostPosted: Tue Aug 11, 2009 4:25 pm
as if hijack my thread!
i really want to run it on pumpo fuel as well, in particular unleaded
you can get it pretty much anywhere here in Oz.
Shazzam66
'Valerie' 1966 Chrysler Valiant VC with 3.7 litre 225 Slant 6 backed by A904 3 speed Torqueflite
PostPosted: Tue Aug 11, 2009 4:46 pm
Site Admin
i really want to run it on pump fuel as well, in particular unleaded
No. That isn't going to work.
CJ
PostPosted: Tue Aug 11, 2009 5:06 pm
what about 98 octane then?
gah
so many decisions
Shazzam66
PostPosted: Tue Aug 11, 2009 5:20 pm
Site Admin
Do you want it to make nice noises and go pretty good?
Or do you want it to go like an evil rabid cheetah?
Do you really need it to go like a cursed flying rodent, or do you want the image of something nasty?
It's OK, I've had V8 rigs that sounded like they just came off the Nascar circuit that couldn't pass a Yugo with a tail wind. :lol:
What are you really trying to do here? For the cruise, you can make some interesting noises, still run pump gas, and maintain economy.
I run 15's with something relatively nasty, premium fuel, and get around 15 mpg, sometimes better. Some V8's are slower. But I don't drive the thing except to the races. I have an econobox for actual transportation. :wink:
CJ
PostPosted: Tue Aug 11, 2009 5:30 pm
so in that case were can i hope to win on the streets against good v6's and small v8s
1 guy told me to use 3 11's in the diff
I think you mean 4 11's, as in 4.11:1 ratio. Yes a gear change that big will make a big difference to your acceleration, but will also drive you crazy on the highway and hurt your fuel economy.
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Tue Aug 11, 2009 7:35 pm
I've been 12 flat at 110 in street trim in a 3200#+ car. I was on spray, but not pump gas. The car would run 14 teens all day long on motor and 93 pump gas.
The bad part about wanting to knock off V-6's and small V-8's is they may not be very stock. The flip side is that they may just be a pig.
I knocked off stock 5.0 Mustangs like clockwork on motor only, and even did in some pig blocks.
I also had my azz handed to me on spray by non-stock 5.0 Mustangs and LS-1 Firebirds and Camaros.
I did put a thumping on a '68 Hemi Charger at a RT. 66 Mopar Show once. I went 14:75 and he went 16:50. Not all Hemi's have been tuned up or driven well.
First thing you really need to do is form a realistic opinion of what you want.
Also, get that stupid notion of a stock bore motor out of your head. You already want to fight with one hand tied behind your back, why make it worse on yourself? :shock:
PostPosted: Tue Aug 11, 2009 7:46 pm
Depends on tire size and highway speed limits(or personal ones...) I have run a 70 dart with a mild/kinda mean 225 904 and 3.55 gears. with 26 inch tall tires I could cruise the highway at 75-80 3700-3900 rpm and still knock down 21 mpg.Same combo got 24 mpg at lower speeds. Its all about the combo and how you use it...but I agree 4.11's are pretty hairy without an overdrive above 65 mph!
PostPosted: Tue Aug 11, 2009 9:18 pm
im thinking to switch the 3 speed auto for a 904 4 speed auto
would probably make it drive a lot smoother
Shazzam66
PostPosted: Tue Aug 11, 2009 9:46 pm
:?: But a 904 is a 3 speed auto....Unless you buy a very expensive gear vendors overdrive unit.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Wed Aug 12, 2009 12:38 am
think i may have meant something else...
never mind
can anyone recommend a good 4 speed to bolth to the back of a 300hp s6
Shazzam66
PostPosted: Wed Aug 12, 2009 9:21 am
never mind
The A833 4 speed is a tough tranny and very hard to destroy.
PostPosted: Wed Aug 12, 2009 9:26 am
Car Model: 1962 Lancer 770
But unless you get the OD version of the 833, your final drive ratio is still 1:1 and you'll still be going crazy with 4:11 gears. I have a 3.80 rear drive and on 1:1 its unpleasant starting at 50mph...
MJ
PostPosted: Thu Aug 13, 2009 6:32 pm
Since you really can't figure out what you are trying to do, here's a present for playing our game. :D
