It is currently Sun Nov 15, 2026 12:10 pm
PostPosted: Wed Aug 12, 2009 5:47 am
so i got my engine put together and i lined the timing marks up dot to dot (which will be degreed later this month)and i'm a TDC #6 would that create a problem. i tried to get it at TDC #1 but it wouldn't line up. yall know what to do?
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
 Post subject: tdc and timing
PostPosted: Wed Aug 12, 2009 6:18 am
Ok; Each piston rises to the top twice in the cycle, you are 180 degrees off,
bring your #1 back to top dead center(your rotor should now be pointing to#6) remove and replace your distributor so rotor now points to #1.
good luck
robert
PostPosted: Wed Aug 12, 2009 7:42 am
do'nt panic. it is right. when the timing marks on the cam and crank sprockets are lined up, #6 is at TDC. see this post
regards,Rod :D
PostPosted: Wed Aug 12, 2009 7:55 am
thanks i though i messed somthing up bad
Users browsing this forum: Bing [Bot] and 5 guests
