It is currently Fri Nov 13, 2026 3:10 am
PostPosted: Thu Aug 13, 2009 10:44 am
Do any of you know about this distributor? I know it fits the /6 but thats about all. It has 3 wires and I assume that one is for the neg post on the coil, one is possibly a ground but not sure about the other one. I do know they need a ballast resistor but I don't know what ohms it should be. Can anyone help me out here?
PostPosted: Fri Aug 14, 2009 6:32 am
Google that dizzy. I think one of the leads is tach.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Aug 14, 2009 8:03 am
Go to the Mr gasket web site, then Mallory. The wiring dia is in the instruction section.
Red goes to 12 volt side of balast resistor
Green to neg side of coil
Brown to ground
The pos side of the coil goes to the other post of the balast resistor.
 Post subject: You guys are the best
PostPosted: Sun Aug 16, 2009 7:29 am
I knew one of you would know where to get this info. Thanks for your help. I noticed that in the instructions it warns against using solid core cooper or steal spark plug wires. Instead, use spiral wound or radio suppression wires so that you don't ruin the electronics. That was to good to find out. Again, thanks all for all your help! :D
