It is currently Sun May 03, 2026 5:14 am
 Post subject: Car weight
PostPosted: Fri Aug 14, 2009 6:40 am
I'm looking for the weight of 2 different cars. 1974 Dart and a 1966 Valiant both 2 door slants with auto's
Thanks
PostPosted: Fri Aug 14, 2009 7:38 am
Need to know more about each car. Disc/drum brakes, power or manual steering, AC, etc. If the '74 is a sparse as most '66s it will probably still weight 400 lbs more and can go up considerably from there.
PostPosted: Fri Aug 14, 2009 7:45 am
I'll get more information to you as soon as I can.
PostPosted: Fri Aug 14, 2009 8:58 am
see here
regards,Rod.
:D
 Post subject: Just at a run...
PostPosted: Fri Aug 14, 2009 5:49 pm
Just for kicks, My '76 Feather Duster with the spare/full tank of gas/tool in back and my 250 lb butt in the driver's seat weighs out at 3500 lbs...
So the '74 dart in stocker trim and an average american behind the wheel is going to be in the 3400 lb range or so.... The 66 would be closer to 3-400 lbs lighter dependingon equipment.
