It is currently Tue Nov 17, 2026 6:27 am
PostPosted: Sat Aug 15, 2009 1:05 pm
I been working my butt off trying to get the darn holley 1920 carb running and soo far i got it running, albiet a higher idle, the only issue is that whenever i slow down to a complete stop it will diesel and stall on me immediately unless i have my foot on the throttle a little bit.
I really want to get this fixed before college starts.
71 dodge dart custom
1988 Honda Civic ((Because racecar))
2005 VW Jetta
1963 AMC Rambler American 440
PostPosted: Sat Aug 15, 2009 1:47 pm
In THIS THREAD you said:
...so i decided to do a partial rebuild and clean everything that i could take apart inside the guts.
Can you tell us what a partial rebuild includes? Did you get new gaskets?
That made it run better but now we had an issue of a certain vaccuum forcing the car to stall, if i plug the vaccuum it will not stall at all and drive normally,
Do you mean a vacuum hose? What does it go to or where is the leak? A vacuum leak could easily cause your problem.
Danny
PostPosted: Sat Aug 15, 2009 7:52 pm
Its a vacuum for the economizer, whenever it lifts the economizer the car will immediately diesel and stall, my neighbor suggested that i close out the economizer vacuum hole so it wont engage/disengage the economizer, we made a gasket that covers the vaccuum passage in the carb but he wants me to get a thicker one, if i keep the economizer pressed against the power valve lever it runs fine.
2005 VW Jetta
PostPosted: Sat Aug 15, 2009 10:54 pm
Your carb is plugged up with something. Take the Economizer body off and clean it very carefully with spray. You may have to soak it in carb cleaner.
PostPosted: Mon Aug 17, 2009 1:50 pm
Would I be out of line to offer you a rebuilt 1920 for 50$ ??
Ran great on the Slant 6 in a 71 dart, I live in zip 93610,
you can PM me if interested.
PostPosted: Fri Aug 21, 2009 3:28 am
Ehh I tried cleaning the economizer twice as of today, still stalls, I think its running rich, ill adjust it soon.
2005 VW Jetta
PostPosted: Fri Aug 21, 2009 7:39 am
What size jet are you running?
