It is currently Tue Nov 17, 2026 2:57 am
PostPosted: Sat Aug 15, 2009 10:31 pm
Diego Ted,
Sorry I didn't see your post earlier. If you clicked on the red link below my name and took a look at the pictures, that's what I did to solve the problem. Two 1/2" thick gaskets does the trick. I installed longer studs to run them. I have been running that set up for about two years now. No problem with the idle ever or on restarts even on 100 degree days.
I run the R7585 1920 Holley Economaster.
EconoMaster 1920 Holley R7585 modifications:
This set up really wakes up the engine!
Reference: .078 = 5/64th
Idle mixture hole .080
Idle air bleed #65 drill, .035
Squirter hole #65 drill, .035
Idle @ 4 turns with #61-2 to #64 jet
The pump shot is very strong, enough to break the rear loose with a 2.76 posi.
For good mileage:
2009 changed back to nearly plugged idle air inlet by peening hole with round tip on scribe. The hole is a very small idle bleed inlet @ .005. with a #57 jet and idle mixture set @ 1 7/8 turns.
Glad you figured it out and that it's working for you! :D
PostPosted: Tue Aug 18, 2009 10:28 am
heres my heat deflector i made for the bbd super six setup,with a 4 dollar piece of scrap aluminim,a hole saw and cut off wheel, and it works great.
got more pics if anyone wants em.
PostPosted: Tue Aug 18, 2009 10:38 am
1980volare,
Very cool! I bet your carb doesn't heat soak now! It sure made a big difference on mine.
PostPosted: Tue Aug 18, 2009 7:56 pm
Hey I just found page 2!! Thanks Ag Ted! I am looking forward to trying the carb mods@@
Diego
DiegoTedRacing.com
