It is currently Tue Jun 02, 2026 4:22 am
PostPosted: Sat Aug 15, 2009 9:03 pm
I need some timing chain part numbers so I can order one up. Does anyone know of say an adjustable set??? If you read this and know a make and part bnumber I need it but tomarrow by 730 pm PST. thanks everyone :D .
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
 Post subject: Rollmaster set...
PostPosted: Sun Aug 16, 2009 8:55 am
CS5302 I think....
PostPosted: Sun Aug 16, 2009 11:15 am
yep, CS5302. about halfway down this page,
http://www.romacusa.com/Rollmaster_Applications.pdf
zedpapa
soon to have 5 gears!!!
PostPosted: Sun Aug 16, 2009 4:16 pm
You guys know one that maybe Summit might carry??
PostPosted: Mon Aug 17, 2009 8:47 pm
FYI these #'s will get you a double roller timing chain from Cloyes avaible at Summit.
clo-c168
clo-s338
clo-s339
 Post subject: Yep...
PostPosted: Mon Aug 17, 2009 9:12 pm
You can use those parts, and you'll need to order a bushing set too... All the Cloyes parts were available individually from all your local stores (even Autozone).
PostPosted: Tue Aug 18, 2009 8:14 am
What bushing set? Do you have a part # for it D.I. ?
 Post subject: Any kit will do...
PostPosted: Tue Aug 18, 2009 6:41 pm
The kit is generic so you can order a crane kit for a Chevy, or a Mopar Performance kit...Just shooting from the peanut gallery, Mr.Gasket #85 for chevy and mopar, or Mopar Performance P3960936?
PostPosted: Tue Aug 18, 2009 6:46 pm
I have both of the MR Gasket kits 85 and 85A one is 0 2 4 the other is 1 3 5 degrees.
One is hard to find but cant remember which.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Aug 19, 2009 8:29 am
I am under the impression that a b/rb timing set is close to a \s. Can anyone of you guys tell me yeah or nay. Ive got a wicked idea....... :twisted:
PostPosted: Wed Aug 19, 2009 9:33 am
The bottom gear and chain for the B/RB Mopar engines is the same but not the top gear. The top gear of the set is SL6 only, it has a cup on the back, the B/RB is flat. The timing marks are also in a different place but I never look at those anyway so NBD there.
PostPosted: Thu Aug 20, 2009 6:53 pm
I just bought (on 8-6-09) a double row true roller unit from hughes #HUG-6406 for $49.50 shipped.
I can't seem to find it on their website anymore though and all I find is the cheaper "silent" timing set #HUG-6406S which is only $29.95, but I doubt it's a roller.
1969-1/2 Dodge Super Bee A12 (440 Six Pack, 4-spd, Dana 60)
1974 Plymouth Duster 360 (4-spd, 8.75")
1973 Plymouth Duster (225, auto, 8.25")
2001 Dodge Ram 1500 QC 2wd (5.9L, auto, Dana 60)
PostPosted: Fri Aug 21, 2009 4:18 am
Online
I called Hughs when this thread started, as I had purchased one, also. They are out of stock, and their vendor (Avon Gear) has discontinued them.
They are available from Summit (or anyone that sells Cloyes). The problem is the price (over $100). I had previously purchased some cam sprockets on E-bay for $9.95, so I just ordered some crank sprockets ($29.95), and chains ($17.95), to make some complete sets. The cam sprocket is $53.95. Summit confirmed with Cloyes, that the parts are in stock, and supposed to ship to me about 09-04-2009.
If you want them from Summit, you might want to order now, so they can be included with the parts I ordered. Summit does not stock these parts, they have to be ordered from Cloyes.
PostPosted: Fri Aug 21, 2009 6:42 am
hi sages- following this thread on timing parts. back in 87 my 77 sl6, broke atooth off the original cam gear, the chain jumped and timing went to hell. never did see an sl6 chain bust. bought a set of gears and the chain then for about 20.00. dont think it was double roller chain. surprised that todays replacements are not as easily available given the common presence of the sl6. 50 is a bit stiff. seems clip joints wont ever hesitate to enter a market. the replacement gears were all steel,not fibre like the originals. there was no tensioner on it like cars today. should have been impressed that the engine didnt blow to hell when the timing went like the interference travesties today. worked fine until jersey rust claimed the car at 360k in 05. i recall that the harmonic balancer even though it was pushed all theway back on the crankshaft, almost flush with the cover and then bolted, continued to leak a little oil . was there a crankshaft to balancer seal or gasket, hopefully with a thrust washer that was supposed to go there? want to know that for the the next sl6 chain job.always wondered if there was a contact gear set for the sl6 which eliminated the chain as with some other engines. regards bf
PostPosted: Fri Aug 21, 2009 7:27 am
Wow, I must have got their last one. I'm glad I ordered it when I did as I can't afford to spend more than double what I paid.
Back in 1987 we were parting out 'Cudas, passing up six pack cars and buying running clean B/E-body 4-speed Mopars for $2,500.00-4,000.00
Last edited by daniel_depetro on Fri Aug 21, 2009 7:29 am, edited 1 time in total.
Users browsing this forum: Bing [Bot], Charrlie_S, Google [Bot] and 3 guests
