It is currently Tue Oct 13, 2026 4:22 am
 Post subject: Engine Stall
PostPosted: Tue Aug 18, 2009 6:22 am
IDLE RPM IS 1000
IN DRIVE AT A STOP ENGINE STALLS RPM IS 800 AND BELOW
69 cuda
225 super six
holley 390
offenhauser intake
headers
dual exhaust
PostPosted: Tue Aug 18, 2009 10:56 am
Probably a vacuum leak on the intake gasket, carb or a cracked/missing vacuum hose.
What is it timed at?
PostPosted: Tue Aug 18, 2009 11:33 am
6 to 8 before tdc
but i think its fully advanced
69 cuda
225 super six
holley 390
offenhauser intake
headers
dual exhaust
PostPosted: Tue Aug 18, 2009 11:51 am
How long has it been running like this?
Is this a stock engine internally? or do you have a after market high left long duration cam?
Are you saying you can't advance it to 10 to 12 degrees?
PostPosted: Tue Aug 18, 2009 12:24 pm
its advanced to 10 - 12
three months runnig like this
69 cuda
225 super six
holley 390
offenhauser intake
headers
dual exhaust
PostPosted: Mon Aug 24, 2009 7:08 am
i am having the exact same problem. running 10 degrees timing. offenhauser intake, holley 390, headers, comp cams. 252 duration, .435 lift. i can get it to idle at 1000 but as soon as i put it in drive it just dies. i tried spraying soapy water and also carb cleaner all over everything to see if i could find a vacuum leak and found nothing. this is on a new motor. has 300 miles on it. im lost. my dad seems to think the 390 is too small as it also has a miss like it running lean. yesterday i went from 53 main jets to 63's seemed to help a bit but still has the miss. i did get it to run before, but i had the timing at 14 degrees and the idle mixture screws at 3 1/2 turns out.
it's not only good. it's good enough.
 Post subject: slantscamp
PostPosted: Mon Aug 24, 2009 8:03 pm
slantscamp,I have a 0.460 lift cam in mine and it will idle like a top at 800 RPM.It has 18 HG. of vacuum in gear.double check your timing,it would be best to find your TRUE top dead center using the 'piston stop' method.maybe you have the wrong gaskets in the carb,or a passage in the carb is blocked.Do you have power brakes? the booster can fail causing a vacuum leak.
PostPosted: Tue Aug 25, 2009 5:02 am
I assumed you have adjusted the valves and they are not too tight. This is a classic symptom of tight valves. You could even just loosen them and start up with valve cover off to check idle.
Cam timing could also be off, but do valve adjustment first.
Users browsing this forum: No registered users and 19 guests
