It is currently Tue Nov 17, 2026 12:31 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Wed Aug 19, 2009 1:03 am
I use an AC Delco (it was on the car when I bought it) FV 167 or something like that. Fram makes an FV 167 with a metal base and plastic elbow. No wistle like the plastic ones.
PostPosted: Wed Aug 19, 2009 11:53 am
Dave,
Yes, JB Weld is great for that use.
What kind of vacuum are you seeing now?
The Spectre cap with built in PCV I am using is similar to the GM all metal PCV. No noise or anything to wear out especially when using synthetic oil.
PostPosted: Wed Aug 19, 2009 1:56 pm
Well,I am enlarging the hole a little bit at a time right now , if I give the gas a good punch ,it pulls some vacuum. Sometimes when I slowly raise the RPMs it does nothing until 2700 RPM.When I get vacuum, it does not stay at that pressure ,it will drop.(If I get it up to 5" or 10",it will stay there a second and then drop.)It is better than yesterday ,so I will enlarge the hole a little more ,and then test it again.(don't worry I am not going crazy with the drill bit) :D . I think I am through missing with it today ,its a little warm at 100*
Ted, do you know the part # for your PCV valve grommet?
Thanks
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Wed Aug 19, 2009 2:16 pm
Installed a Spectre Breather w/Dorman #42344 grommet.
Email a picture when your done installing the vapor recycling fitting.
PostPosted: Wed Aug 19, 2009 2:26 pm
I posted some pictures of a spare carb a was practicing on in This
Thread
Dave
81 Dodge D150
PostPosted: Wed Aug 19, 2009 3:54 pm
Well, I decided to go ahead and try it once more, and now at 2000 Rpm I get a steady 8" of vacuum. I think that is good ,because I tested the purge canister valve and it opens up at around 5" of vacuum.If I have time tommorrow I am going to hook up both ported vacuum ports on two seperate gauges and see how they look.
Hopefully it will be successful
Dave
81 Dodge D150
PostPosted: Wed Aug 19, 2009 9:38 pm
Dave,
Most excellent work! Glad you gave it a try and weren't afraid to follow through. :D
It should work just as well as mine.
PostPosted: Wed Aug 19, 2009 10:58 pm
Thanks for the help
Dave
81 Dodge D150
