It is currently Fri Nov 20, 2026 1:25 am
 Post subject: eight inch ford rear.
PostPosted: Sun Aug 23, 2009 1:47 am
I know that I might be asking some dumb questions but here goes;
What is the deal with the 8 inch rears, which ones would be the best to use with the a-bodies. Do these rears hold up to much HP? Just asking cause a buddy of mine has an 8inch out of a 67 mustang that he will sell cheap. It has the axles and housing and pumpkin [no backing plates or drums/brakes.] Are the 8" rears alot lighter? [than say an 8 1/4] I guess they would be easier to find it seams. Which ones are the more narrow ones? mustang, maverick, pinto?
What about the center "register" on the axle flange. is it different?matter?
basically, what are the main advantages to using the 8"?
[guess the dropout chunck would be one advantage]
{hey, I'm answering my own questions.....thats ok I frequently talk to myself and answer my own self, LOL} Im losing it!!
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
PostPosted: Sun Aug 23, 2009 6:58 am
The Maverick 8" rear will more or less drop right in, without any hassles, on an A body.
Advantages
  • right bolt pattern
    relatively light weight
    durable
    easy to get parts (including new gears)
    easy to install
Disadvantages
  • need a conversion U joint
    Need the bigger U bolts and shock plate
    Ford product, and will have to suffer some embarrassment
    ball bearing axles are probably not as strong as tapered bearings, if you are really going to do hard road racing.
PostPosted: Sun Aug 23, 2009 8:59 am
6 Pack Dart
You don't need to use conversion U-joint have ford end put on your drive line. Over all length might be different measure to make sure, and check the length of the axle, that is the over all length from flange to flange where the wheels bolt on.
PostPosted: Sun Aug 23, 2009 11:12 am
Getting the right one is very important. '67 Mustang (59-60" flange-flange) is too wide for any RWD wheels, even late model Mustang wheels. You might get it to work with some FWD wheels with even more offset (like >+40mm offset)
Best ones are '64-66 Mustang, Mavericks, and Granada/Marquis. Granada axles are 58" flange-flange and the others are about stock Mopar width (56.5" or so). Granadas are the ones to get to use Mustang wheels.
Too bad you didn't peek under my '68 Dart at Kearney since I have a Maverick one in there...
Supposed to be good to ~350-400 HP, so fine for us, and weight is at least 30lbs less than an 8.25" or 8.75" Mopar axle.
Please do a search on this site and there will be a lot of info.
PostPosted: Sun Aug 23, 2009 11:39 am
6 Pack Dart
This might help,
http://www.ridgenet.net/~biesiade/Fordrears.html
PostPosted: Sun Aug 23, 2009 10:02 pm
thanx guys. Very helpful info.
1979 W150 Shortbox
The Good Life.
PostPosted: Mon Aug 24, 2009 6:24 am
Make sure you check the gear ratio. My son's '77 Monarch had a 2.47:1 gearset. :shock:
