It is currently Wed Oct 14, 2026 5:10 am
 Post subject: Hole inside intake
PostPosted: Fri Aug 21, 2009 8:43 pm
I'm suffering from search function overload so if this is an old question sorry :oops:
Ok inside my supersix intake is the hole(under carb area) where exhaust gas from EGR was introduced back to the intake.So the thing that's bugging me is what do we do with this hole? With EGR removed/blocked off it leaves a fairly big cavity to collect gas under floor of intake with nothing to push it out.I suppose that the suction of intake might draw anything out of said hole/cavity but just not sure.So am I just over thinking this?,not a big problem? There's no threads in it so threading cast intake for a plug just doesn't set right with me,I have visions of the intake craaaacckkkking :shock: Thanks all
PostPosted: Fri Aug 21, 2009 11:20 pm
The gas will evaporate out............
 Post subject: I put a plug in mine
PostPosted: Sat Aug 22, 2009 6:03 am
If it is an iron intake like mine threading for a plug was not a big deal. If it is an aluminum 2bbl then I am not sure. I got the idea of a plug from another post here a while back and my old school mechanic didn't seem to think it would hurt the manifold. I just ran a coarse thread tap through a few times and put in a pipe plug. There seemed to be lots of meat there so its shouldn't crack.
cheers
Brent
Arizona Duster in Canada
PostPosted: Sat Aug 22, 2009 8:42 pm
JBWeld it and "faggittaboutit."
PostPosted: Sun Aug 23, 2009 7:48 am
I'm with Rugtrucker. :)
'78 Volare 225
'67 Charger 318
PostPosted: Sun Aug 23, 2009 8:52 am
I JB Welded mine about 3 years ago. Still looks good today!
I made it into a small mountain with a rounded top.
PostPosted: Sun Aug 23, 2009 10:34 am
JB Weld it is then 8) I'm thinking maybe to grind the raised area level with the floor of intake to smooth out the flow,what say you all?
PostPosted: Sun Aug 23, 2009 12:27 pm
Not needed,waste of time,,,,but thats what I would do,Mark
PostPosted: Sun Aug 23, 2009 12:52 pm
And me too,I figure it's like "Chicken soup for the motor",it couldn't hoit :wink: Plus I have all winter to play with it or maybe the grandkids can scratch their heads someday wondering "What the heck was Papa trying to do 8)
PostPosted: Sun Aug 23, 2009 12:59 pm
Ever seen a "turtle" for the single plane intakes? JBTurtle!
PostPosted: Sun Aug 23, 2009 7:55 pm
Yes! as a matter of fact I have! :)
My single barrel intake is all aluminum. It seems to stick just fine and the gas does not soften it. I think the little JB Weld mountain/turtle helps to disperse the gas vapors.
PostPosted: Mon Aug 24, 2009 4:56 am
If only they made a "Turbinator" for the super six! :lol:
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 54 guests
