It is currently Thu Apr 30, 2026 3:56 pm
PostPosted: Sun Jul 26, 2009 3:59 pm
SSRN National Champion
Ok I understand now. Thanks Ron Parker :D
Bee Good Or Bee Gone
PostPosted: Mon Jul 27, 2009 6:27 am
I doubt the M-1 flows any better than the stock iron or aluminums. It is a great casting!
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Mon Jul 27, 2009 12:45 pm
The M1 is going to heat up quicker for drag racing and a little easier to port match.
PostPosted: Mon Jul 27, 2009 1:01 pm
The M-1 manifold is not legal for stock eliminator.
PostPosted: Mon Aug 24, 2009 8:05 am
Well we tested a 043, 595 and a 578. I went 3 hundreths quicker with 578 but it is about 15 lbs lighter and I didn't add any weight to compensate so they kind of equal out. All in all I would say no differance.
BTW it did eventually go 1.028 under the index.
PostPosted: Mon Aug 24, 2009 2:53 pm
Phil,
Is the 578 the good solid cast aluminum (not welded), truck two barrel manifold?
Where did you go to do the tests?
PostPosted: Mon Aug 24, 2009 10:41 pm
The 578 is a welded intake, I was at mission raceway.
