It is currently Mon May 04, 2026 11:37 pm
 Post subject: Air Intake Hose ?
PostPosted: Thu Aug 27, 2009 3:02 pm
Does anyone know where I can get an air cleaner intake hose at .It seems to be like a 3 1/2" hose .Mine is beyond dry rotted
Thanks
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Thu Aug 27, 2009 3:17 pm
Sounds like you need
DUCT TAPE
PostPosted: Thu Aug 27, 2009 4:02 pm
I am a stock holder in duct tape , and this may be the only thing duct tape can't fix :lol:
Dave
81 Dodge D150
PostPosted: Thu Aug 27, 2009 4:29 pm
I just bought the stock hose at NAPA for an 80's air cleaner. Both of our local Auto Parts Houses here in Black Diamond carry them for all the years. I believe they are 3" and they come with the clamps built in.
PostPosted: Thu Aug 27, 2009 4:36 pm
Ted, do they have them in stock?
I took the end off of the air cleaner ,so I will have it with me to test.
Thanks
Dave
81 Dodge D150
PostPosted: Thu Aug 27, 2009 9:09 pm
Most of the hoses are a few hours away if they don't have them in the store. They happened to have mine on hand that I used in the pictures on the link below.
PostPosted: Fri Aug 28, 2009 4:20 pm
I went to 3 Napas and none of them had any kind of intake hoses, and the one closest to my house called the makers, and they said they stopped making them. I guess I am going to put my brain in Macgyver mode. :D
Dave
81 Dodge D150
PostPosted: Sat Aug 29, 2009 4:32 pm
I found a 3" flexible aluminum duct at Lowes . It just crams inside the opening , but that is good. After I give it a couple of coatings of some black undercoating spray, I think it will be good.I decided to run it right beside the radiator ,and getting fresh air from the grill.When I get it complete, and remember where my camera is , I will post a pic.
Dave
81 Dodge D150
PostPosted: Sun Aug 30, 2009 2:21 pm
Dave,
The brand our Autoparts carry is the "Motor Mite" brand air intake hose. I had them look up one for an 80 Dynasty which I believe is the air cleaner base that I am running, (bought it off eBay) but a 77 Aspen will do too. Part number they gave me today was #96080 but need to double check. They went to a square end on some. I am not sure if I still have the old yellow and green box or not.
Rock Auto has them also.......
Standard Motor Products Part# DH11 16" long with built in clamps $8.98
or
Airtex Part# 1F1021 16" long with built in clamps $9.54
Anyway they are commonly available.
Hope this helps! :D :D :D
PostPosted: Wed Sep 02, 2009 11:43 am
Here is what I came up with , with the flexible aluminum duct and some paint.
I decided to run it to get max airflow , so this is what I came up with.
This is just my rough draft of it,let me know if this would be good
Thanks
Dave
81 Dodge D150
PostPosted: Wed Sep 02, 2009 1:04 pm
PostPosted: Wed Sep 02, 2009 1:23 pm
Thanks, I need to get another hot air duct .I have been taking the carb on and off, and I am planning on putting on some remfex gaskets when they come in , and I think that should take care of any possible vacuum links tht I could have left.
Dave
81 Dodge D150
Users browsing this forum: Ahrefs [Bot] and 1 guest
