It is currently Tue Nov 24, 2026 2:19 am
PostPosted: Wed May 14, 2003 3:52 pm
If somebody is interested, here is instructions for A/F ratiometer http://home.pi.be/~oo461621/jetta/airfe ... meter.html
There is few different designs.
Price for those components is here in finland about 12 € (or $).
Joug
Sorry, my english is not very good
PostPosted: Wed May 14, 2003 6:21 pm
Cool, man! Thanks for the link. Keep wrenchin' in Finland!
'68 Dodge Dart 4dr Sedan
PostPosted: Thu May 15, 2003 11:45 pm
Car Model: 1964 Valiant
Where is the best location to install an O2 sensor on a OEM cast \6 iron manifold ? Are two sensors better than one ? Some new cars have up to five O2 sensors. The O2 sensors are a common failure point on newer cars.
I would like to add an A/F meter although I plan to keep a carburator for the time being. I want to convert to EFI eventually. I think it would be helpful to know the fuel mixture at all times.
PostPosted: Fri May 16, 2003 12:06 am
Tim, if you don't care about your heat riser valve then remove that and drill yourself a nice big hole. That is a perfect spot. Threads on typical o2 sensors are 17 or 18mm I believe. With the sensor that close to the manifold you wouldn't need to get a heated o2 sensor. And if you ever decide to use a different exhaust setup you can still plug it up with a bolt.
PostPosted: Fri May 16, 2003 1:07 am
I want to keep the factory heat riser valve. I have a exhaust manifold from a truck which appears to be extra thick with heavy cast ribs. Perhaps I can drill the hole in the heat riser, but placed so that the O2 sensor won't interfere with the valve flap?
PostPosted: Fri May 16, 2003 1:22 am
You want the o2 sensor in a spot where it will see the exhaust of all cylinders. On some other v engines they had only one o2 sensor on one side which effectively saw 1/2 of the cylinders exhaust, but this wasn't such a big deal because a/f distribution is more even. I'd say to get a accurate reading with a /6 (especially since you might be using the same sensor for a future efi setup) either put it near the heat riser or just below the flange in the exhaust pipe. If putting it near the heatriser remember to allow clearance because the sensor will stick in the hole a good 1/2" or so.
PostPosted: Fri May 16, 2003 4:30 am
I put my O2 sensor right after exhaust manifold to the exhaust pipe. I drilled ~20 mm hole to the pipe and welded piece of iron with correct thread in it. It's good if you also make smaller thread to that piece of iron so that you can put the earth wire of O2 meter there. It's also good to use protected wire from O2 sensor to the meter. I do not know how you call protected wire, but I mean wire, what have earth wire arounded the hot wire.
Because voltages from O2 sensor are under 1 volt, with protected wire there wont be so much interference.
Joug
PostPosted: Fri May 16, 2003 4:38 am
shielded is the word your looking for. That is an interesting thought and in principle I would agree with you but all the modern cars with stock o2 sensors I've seen didn't use shielded wire for the o2 sensor.
PostPosted: Fri May 16, 2003 9:04 am
Thats true Pierre, But this is what i have found better when using o2 sensor. Normally also those wires are shorter when they are controlling fuel system. But when you'll bring that wire inside it's maybe 2 meters long. And when i changed that wire to shielded , it came steadier.
Joug
PostPosted: Fri Jul 04, 2003 1:52 am
I made that 20 led a/f meter and it's great, much better than voltmeter. Of course voltmeter is ok, but this meter is more visualizing than numbers in voltmeter. It's also very fast and if a/f ratio is fluctuating you can really see it.
In that page I put in my first post, is not so complete than this:
http://www.multi.fi/~alahti/seosmittari.htm
Problem may be, that it's finnish language, but You really don't need anything else than circuitboard pic. and this circuitboard is made so that you need only one jumper.
Joug
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
