It is currently Fri May 01, 2026 1:56 am
 Post subject: Shift cable adjustment
PostPosted: Sat Aug 29, 2009 4:21 am
Hi all,
Finally got around to putting the push button shift back in the '64 Signet and need a little help with the adjustment. I've got the car up on jack stands and in park all seems good however when I have the park lever off and the car in neutral the rear tires roll forward. Do I need to spin the adjustment wheel on the cable at the tranny in to pull the cable out more or do I spin it out to push the cable in more? Followed the instructions in the FSM by lining up the first hole and then turning to the fifth hole, seemed simple enough but I guess somewhere along the way I jacked something up. Any advice?
Thanks, Jeff
By the way, I've got a floor shift unit in excellent shape complete with cables and wiring I'll be looking to sell. Not sure what year it came from but I can get some pictures.
PostPosted: Sat Aug 29, 2009 6:35 am
Can you stop them by hand easy? You may be fine. You still move the fluid in the trans even with the car in neutral. In park the sprag is engaged so it wont move.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Aug 29, 2009 8:07 am
No I can't. Looks to me, judging by the rpm the tire is rotating minus the weight of the car, I may be running close to 5 mph.
Jeff
PostPosted: Sun Aug 30, 2009 6:09 am
OK
Back to the R&R phase. I think you may have some more adjusting to do.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Aug 30, 2009 7:06 am
Your cables came from a b body correct? I wonder if the crimped ends are different length than a valiant's-- What I mean -- they might be just a little longer /shorter causing your adjustment to be off--.
I know when looking at a 65 cable vs 64-62 they look the same until you get up close & inspect them. (the ends are slightly different)
Just fyi--
Lawrence
