It is currently Sun Nov 22, 2026 3:52 am
PostPosted: Wed May 14, 2003 7:13 am
Hey folks,
Well, Cycledog did some boneyard searching and found that an '88 5th ave 318 "straight out" waterneck fits the Slant essentially perfectly. This should be found on '80s-'90s SB Mopars, and only needs the bolt holes drilled slightly. They use the same gasket as the Slant and the same thermostat type. Thanks C-dog!
<BR><IMG SRC=http://images.prosperpoint.com/518/26910-153.jpg WIDTH=275 HEIGHT=240>[/img][/list]
These are listed new at Rockauto.com for $6, and I verified that the part numbers for gasket and thermostat are the same as the Slant Six. I will be putting one of these on my '64 Dart soon.
Cheers,
PostPosted: Wed May 14, 2003 2:47 pm
:) Wow, that's pretty cool Lou. I'll have to pick up one (or two) of these next time I'm at the boneyard.
'78 Volare 225
'67 Charger 318
PostPosted: Wed May 14, 2003 6:50 pm
Cycledog is the one to thank. :)
This is only good for non-OEM radiator setups like the aluminum one I have on my '64.
Cheers,
