It is currently Fri May 01, 2026 11:11 am
 Post subject: Mirror
PostPosted: Sun Aug 30, 2009 11:10 am
OK. I used the search function but no dice. How do I remove the side view mirror from the housing so I can tighten the ball and socket. I know I read how somewhere here but alas I can not find the post.
Thanks Phil
PostPosted: Sun Aug 30, 2009 9:35 pm
I would like to know this fix as well...
PostPosted: Mon Aug 31, 2009 1:25 pm
Someone, U think SSD posted a pic of how it goes but I can't find it
PostPosted: Mon Aug 31, 2009 4:54 pm
There is a flat spring washer that holds it in place-- like a snap ring with out the holes to pry apart(it is the diameter of the mirror)
look closely at the face of the glass you will see it-- get that out with out breaking the glass-- & then you can tighten up the mirror.
good luck!! Lawrence
PostPosted: Tue Sep 01, 2009 5:21 am
Unfortunately not all mirrors have that "snap ring". Some of the mirrors are glued in. If it's glued good luck getting it out without breaking the glass. replacement glass for the smaller mirrors is hard to find also. (I'm still looking)
64 barracuda
64 valiant convertable
65 valiant sedan
65 signet
74 vw beetle convertable
79 E-250 4WD van
94 dodge dakota
PostPosted: Tue Sep 01, 2009 1:30 pm
I actually have both kinds. I had a new mirror cut locally it was like $12.
its the snap ring kind that need tightening
PostPosted: Wed Sep 02, 2009 2:57 am
Well that's the easy fix. I'll have to check for a local place to do that.
64 barracuda
65 valiant sedan
65 signet
79 E-250 4WD van
94 dodge dakota
