It is currently Mon May 04, 2026 12:22 pm
PostPosted: Sun Aug 30, 2009 10:02 pm
ok i know the EFI ff the 4.0 is suppose to be a direct bolt on for the 225.
are there any other parts like the headers or anything else that might interchange
alrighty thanks for any info here
PostPosted: Mon Aug 31, 2009 3:39 am
Sorry, it's not even close. Port face and port arrangement is different. No manifolds or headers interchange for this reason.
The Jeep 4.0 and older I6 shares nothing with the slant except that the extended tip spark plugs used in many 4.0s fit the '74 and older slants just fine. No moving parts interchange. No castings that I can think of interchange. Only incidental small parts have a chance of interchange.
PostPosted: Mon Aug 31, 2009 4:58 am
The motor oil and the gasoline interchange readily. :D
PostPosted: Mon Aug 31, 2009 5:22 am
Car Model: 1967 Dodge Dart GT
maybe youre thinking of the inline amc engines that were the predecessors to the jeep 4.0? iirc some of the jeep parts can be made to work with the amc stuff.
PostPosted: Mon Aug 31, 2009 10:37 am
I've owned both the Dodge 225ci /6 and the AMC 258ci I-6 (almost identical to the later 4.0L) and to the best of my knowledge, nothing much interchanges except possibly also the temp & oil senders and that which has already been noted. The AMC produced good torque and was very good and very reliable in my '73 Hornet. I really liked that car, but it just fell to pieces up in the rustbelt. (My wife hated its looks and was glad I don't have a Hornet anymore.)
AMC tended to borrow parts from the big 3 with a few exceptions.
My AMC charging system was an very oddball Motorola that always tended to give problems; the starter and starter relay were Ford. The point-type distributor was GM. The carb was a Holley economaster replacement that did very well (I once read that at that time the single biggest cause of wasted gas in the US were AMC sunken carb floats).
I'm pretty sure AMC used a modified Torqueflight (TorqueCommand?) at the time, but I seem to remember that it had a different bolt pattern.
PostPosted: Mon Aug 31, 2009 7:05 pm
i see well i was mis-informed
i'm glad i asked before i bought the set up this weekend at pick n pull
gonna try to find a newer head and other odds and ends
PostPosted: Mon Aug 31, 2009 8:00 pm
im not really awake right now (woke up after taking some cold meds) but i was saying the jeep stuff can go on an amc engine, not that amc stuff can go on a slant, although i did keep my accell aftermarket coil i had in the hornet and put it in the dart recently :) just wanted to make sure that was clear. and glad that you got things straightened out before buying any unneccesary parts! good luck with your project!
