It is currently Mon May 25, 2026 1:23 am
 Post subject: Exhaust Manifold Woes
PostPosted: Thu Sep 03, 2009 9:15 am
Finally got around to finding the exhaust leak in my 71 Satellite. The bad news is the manifold is cracked almost all the way around just behind #3, even through the reinforcing ribs. Sometime in the past the triangle washers were put on with the conical nib against the manifold. Could this have caused the crack?
Looks like I have 3 options.
1. Weld up the crack. Probably not a good idea.
2. Junk yard manifold (1980 & newer). I'm leaning this route.
3. Headers
What's the consensus? Are headers enough of a gain to justify the expense and possible problems? Thanks.
PostPosted: Thu Sep 03, 2009 9:29 am
Option #4 "Split" the cast iron exhaust manifold into 2 pieces.
Hey, if it wants to be two pieces... make it 2 pieces!
Have you read this article?
http://www.slantsix.org/articles/Slant_ ... lation.htm
PostPosted: Thu Sep 03, 2009 4:26 pm
you can also buy a new manifold, I just put one on my convertable a couple of months ago.
