It is currently Sat May 09, 2026 11:04 am
PostPosted: Sat Sep 05, 2009 1:46 pm
Hello I took off the Transmission on the driver side because its locked up. I have it soaking in solvent but my question is. Can new / used ones be found or can I fix the one I have because it looks like its al pressed together..
Any information would be helpful
Thank you
 Post subject: stuck wiper transmission
PostPosted: Sat Sep 05, 2009 3:31 pm
i had a frozen wiper pivot assembly. i brought it to machine shop
and they ground end of shaft and removed arm and worked it
loose and filled tube with grease and welded arm back on.
maybe keep soaking it and tap it and shake it to free it.
PostPosted: Sat Sep 05, 2009 3:34 pm
Pulled it out of the car. not only is it frozen a tab on it is broke. just had one ear holding it up so I am looking for a whole one at this point. Anyone know what all years used this and what model also?
PostPosted: Mon Sep 07, 2009 11:55 am
anyone know what years and makes will interchange with the 74 swinger wiper transmission. I found one for a 65dart on ebay but the pitcure is a bit fuzzy..
 Post subject: which part
PostPosted: Mon Sep 07, 2009 7:57 pm
try website car-part.com, enter your car in and see which yards have the part and note the part number, then enter another car year and see if
same part number comes out, also you could try email them and
ask for part interchange.
also could try welding the ear back on.
 Post subject: Jeeez...
PostPosted: Mon Sep 07, 2009 8:44 pm
That's like a 71-76 item...the 60's version uses the spring clips on them not the nylon bushings... I wish I would have known, there was a '73 dart at the local pick a part, I just grabbed parts off of on Sunday... if I get time next weekend, I might have time to pull these for you...
