It is currently Fri Nov 20, 2026 6:43 pm
 Post subject: 7.25 Sure grip part?
PostPosted: Sat Aug 29, 2009 8:52 pm
Hi there,
I have 65 barracuda. I am rebuilding the rear end, 7.25 Sure grip differential.
Look like it needs 4 spider gears and 2 side gears.
Does anyone know where these part can be bought? any help would be appreciated.
Thank again,
Andy.
PostPosted: Mon Aug 31, 2009 11:02 am
do you need the mopar part numbers for these gears?
PostPosted: Mon Aug 31, 2009 2:17 pm
I just want to know where I can find spider gear and side gear for 7.25 sure grip.
Do you mean Mopar still have these part? If so, Yes, I need these part number so I can check with Mopar dealer in my area.
Thank you so much,
PostPosted: Thu Sep 03, 2009 7:21 pm
hi, the 2 side gears are part #2404418 and the 4 small gears are part # 2404419. happy hunting...
PostPosted: Fri Sep 04, 2009 2:45 pm
Thank you so much Ronnie,
I found the side gears but almost no hope finding spider gear!!
PostPosted: Fri Sep 04, 2009 5:51 pm
part number 2404419
Silke's AutoParts in Jacksonville, Fl shows 4 in stock. 1-904-737-8600. I have delt with him and think his prices are reasonable.
Collector Auto Supply, Oroville, Wa. shows 22 in stock, 1-800-414-4462.
I have never delt with them, as I thought they were too pricey.
PostPosted: Fri Sep 04, 2009 8:04 pm
Thank you so very much,
I have another question, since I disassembly the differential for replacing spider&side gears, what part do you recommend to replace by the time?
Should it be suregrip clutch plates, pinion shaft, bearing...? and what is the "part number" for these part?
Thank again,
PostPosted: Sat Sep 05, 2009 5:10 am
will post clutch plate kit number and cross shaft numbers. ronnie
PostPosted: Sat Sep 05, 2009 6:54 am
hi, one clutch disc kit #2404427 and spider shaft # 2404420 for quantity of 2. glad to help. ronnie
PostPosted: Sat Sep 05, 2009 5:49 pm
Collector Auto Supply, shows 22 of the clutch packs. Wait till you see the price. I called them about a year ago, and almost went through the floor.
Could not locate any of the shafts. But that does not mean there are none to be had. These are sources that I know to check. Someone may have their own private stash.
I run 7 1/4 rears, and I have some parts in stock for my own use (read not for sale). Post on other forums, and watch e-bay. The last set of clutches, I bought, came from e-bay, and I got lucky, as I was the only bidder, and got them for $29.95.
PostPosted: Sat Sep 05, 2009 9:18 pm
Thank Charrlie,
Do you know if the spider gears and side gears (for Sure Grip Unit) is the same part for 67 Barracuda and 65 Barracuda ?
PostPosted: Sun Sep 06, 2009 3:20 am
Thank Charrlie,
There are two different SG units. The clutch type and the cone type. All the 7 1/4 clutch type use the same parts (two side gears, and 4 spiders), so if both the 65 and the 67 are the original units (clutch type) they are the same. I don't remember what year they changed to the cone type, but it was the in the '70's. I don't know if any SG parts interchange between the two types, but I don't think so, since the cone type only have 2 spider gears.
PostPosted: Fri Sep 11, 2009 3:08 pm
Even I found the sipder and side gears, I couldnt rebuilt the 7.25 sure grip. The problem is all shafts are broken!
Charrlie, Ronnie do you know where can I find the supply for the shaft 2404420 ?
Thank a ton!
PostPosted: Sun Sep 13, 2009 1:09 pm
Bump!
Need it so bad!!
PostPosted: Thu Sep 17, 2009 1:56 am
andy, just keep searching and posting on mopar chatrooms . if you are in a hurry to put it back together , you may have to get a good used suregrip and pull the shafts out of it. ronnie
