It is currently Tue May 12, 2026 2:13 pm
PostPosted: Wed Aug 12, 2009 3:19 pm
I second that..TIG then MIG...but if I only had to buy one... then mig it would be..you can reach into tight spots..under the car or on the bench with nearly no set up or moving equipt. around. (And do it all one handed with your feet up in the air if need be...and yes it does happen :shock: )
I put my MIG on a small cart with wheels (thats was the first welding prodject I did when I bought it) bottle sits nicely on the back. A small shelf over the top of it to put stuff on or use as a mobile bench..A small Lincoln 110v works super for me..
thats my 2 1/2 cents worth..
Its so nice out side, I think I'll go lay under my car..
PostPosted: Sun Sep 06, 2009 5:28 pm
So what do you guys think about this one? I can get one for $250 locall with the co2 tank as well. Will this be good enough for floor pans, quarters etc?
http://www.sjdiscounttools.com/lek6923.html
PostPosted: Mon Sep 07, 2009 6:58 am
That would be a smoking good deal.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Sep 07, 2009 11:47 am
yup way good deal that was my first welder...never ever had a problem with it...perfect welder for beginners very friendly to use..(with practice :D )
