It is currently Sat Jun 13, 2026 5:17 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sat Jul 04, 2009 3:54 am
Thermostat simple one to one was in the Cadillac and the blazer.
Satellite Wagon'72
PostPosted: Sat Sep 05, 2009 3:53 pm
unscrewed the valve, there is only a bolt and spring. I do not understand and twisted back
Satellite Wagon'72
PostPosted: Sun Sep 06, 2009 7:50 am
sprayed brake cleaner, the valve does not go
Satellite Wagon'72
PostPosted: Mon Sep 07, 2009 9:35 am
Can you lightly tap the valve to get it to move? It may require lots of soaking. Try a little tranny fluid around the stem.
PostPosted: Mon Sep 07, 2009 11:42 am
used liquid and soaked day. Poor access to him. Do not go. But spring is easy, does this mean that the valve in the closed position? In the spring attrition, which suggests that the valve works. Am I right?
Satellite Wagon'72
PostPosted: Mon Sep 07, 2009 12:01 pm
Yes, the valve is closed.
You should be able to compress it and the spring together.
When you turn the engine over with the starter the valve should move.
PostPosted: Mon Sep 07, 2009 1:58 pm
ok, i'll try tomorow, tnx
Satellite Wagon'72
PostPosted: Tue Sep 08, 2009 5:54 am
Ted
I think Tod is still working on the thermostat. However I cant be sure.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 08, 2009 7:55 am
realized that the valve moves freely from the finger and did not get it. While fiddling with the oil pump - a lot of oil lost, added 10w-40 4 liters, more liquid oil. Pressure like the norm, even for a drive. Do you think it should still get it?
problem with the thermostat had decided long ago
Satellite Wagon'72
PostPosted: Tue Sep 08, 2009 8:46 am
Tod,
It sounds like everything is good.
Any other problems?
PostPosted: Tue Sep 08, 2009 9:05 am
really need glass rear left lamp. Defeated. There are new, but the right one. as always.
Satellite Wagon'72
PostPosted: Sat Sep 19, 2009 4:04 pm
I need ACDELCO Part # 18A1351, very need.
can some one help me and send it
+Torque Converter for 3L30 transmission
Satellite Wagon'72
PostPosted: Sat Sep 19, 2009 4:23 pm
Transmission is a #904. No such transmission designation as "3L30".
PostPosted: Sun Sep 20, 2009 4:15 am
yes, i need it for another car with 3L30
Satellite Wagon'72
PostPosted: Sun Sep 20, 2009 9:20 am
Why does you say the 3L30? Where did this come from?
Around here we say this A904 transmission.
Cheers, Wizard
