It is currently Mon Oct 12, 2026 12:03 pm
 Post subject: Clocking a slant
PostPosted: Tue Sep 08, 2009 9:19 am
Anyone know how far you can clock a slant 6 up before you get into problems.
I may have some clearance issues with the dizzy and dont want to mod the frame.
This will be on a FED. I know I could go DIS but am not sure I want to.
Thanks,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 08, 2009 10:39 am
The engine (and trans) do not care... as long as you can pick-up the oil in the sumps.
The other problem is at the carb... those work best when operating in a level position.
PostPosted: Tue Sep 08, 2009 11:20 am
Car Model: Toad Wagon
Stock (in my toad) is roughly 2*.
We've run 7* on our (stock pan and pick-up) dragster for a couple years now with no problems.
Actually, a massaged pan would be an easy cobble, and you could name your angle.
As Doc pointed out, carbs would have a say if you're running'em. For seperate reasons we ran a BBD (rotated 90*) on a stock plane manifold this season and had no problems with it.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Tue Sep 08, 2009 3:04 pm
This will have a carb and blower. :twisted: I was thinking of changing the bevel on the head or cut runners and reweld the intake if necessary. I would go EFI (Megasquirt) if I could get the computer stuff figured out.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 08, 2009 3:18 pm
A wedge shaped spacer would be a bit easier and would "technically" add a touch of ram (though you'd be hard pressed to actually measure it :lol: ).
Dick, 225% crazy.
PostPosted: Tue Sep 08, 2009 3:21 pm
I thought of the spacer but I think it would be a sealing nightmare.
Thanks,
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Sep 08, 2009 7:37 pm
Thanks,
Frank
Why??? If everything is machined flat just use 2 gaskets. The blower isn't going to care if it's tipped a couple degrees.
(I am assuming the spacer will go between the carb and the blower, not the blower and the head :shock: :shock: :shock: )
Chris'
Autobody
Restoration
Service
