It is currently Sun May 03, 2026 2:02 pm
 Post subject: shifter question
PostPosted: Sun Sep 06, 2009 5:53 pm
hey guys this may be astupid question but my truck has the od4speed can I get a pistolgrip shifter as long as it is long enough to put in my truck :?
Nothing beats a slant six
1987 D150
PostPosted: Tue Sep 08, 2009 10:04 am
You will need to know the brand of shifter (Hurst, Inland, etc) and know how the stick mounts into the shifter box. (bolt-on or slip-in)
With that info, you can most likely get a pistol grip stick assembly but who knows if the stick's angle(s) will be correct for your truck. May-be you can just order the shift knob (pistol grip style) and mount it to your current stick?
FYI: On all my 4-speed cars, I end-up custom bending the stick in order to place it in a location that is comfortable for my driving position.
FYI #2: I agree that a pistol grip shift knob looks great but I never liked the way they felt when shifting...
I like a "T" handle, cocked clockwise, about 30 degrees. :twisted:
PostPosted: Tue Sep 08, 2009 10:17 am
Contact Gunslinger. They make the Hurst handles. Chances are you have a Hurst mechanism. You can drill the bayonet style and put a bolt in it.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
 Post subject: Yikes!!!!
PostPosted: Tue Sep 08, 2009 7:15 pm
ALERT!!!ALERT!!! We got ourselves a Ford Toploader enthusiast...or a closet Boss/Mach 1 - 4 speed fan.... :wink:
Just kidding!!!!
Your truck should have the Hurst 4 speed shift mechanism. There were a run of pistol grip handle shift sticks out a while back , I suspect the truck might have to use a B-body shifter with some custom bending...the custom A-body one used to be E-body shifters cut and welded to the A-body tab.
I actually like the stock A-body shift stick and the inland 3 speed floor shifter is about right...I think the Ford/Hurst shifter that Doc has referred to, is more comfortable and 'positive' than the pistol grip.
Good luck,
PostPosted: Wed Sep 09, 2009 4:09 am
I had a 4 speed in a '67 Formula S. Hurst Comp Plus. Hurst Black velvet T handle, slight angle on it.
PostPosted: Wed Sep 09, 2009 7:05 am
thanks guys
1987 D150
PostPosted: Wed Sep 09, 2009 7:11 am
are they a member if not can you give me contact info.
1987 D150
PostPosted: Wed Sep 09, 2009 10:06 am
Gunslinger is the company. www.pistolgrip727.com
PostPosted: Thu Sep 10, 2009 6:26 pm
Howdy!
I needed one for my truck too. The throw from 1 t 2 would hit the dash and the pull to 4th would hit the seat. Using a shop press and some chunks of 4 x 6 lumer I bent it just right and it wasn't much trouble. I dummied oneup from an piece of elect. conduit to get the basic shape after about a half dozen trips under neath to bolt it on and take it off.
It might be laying around the shop (the shift lever) if you want it. Since I got out of the 4 speed and into a 727. No pistol grip though, I used the old time Hurst T handle Doc likes.
rock
'64d100
PostPosted: Thu Sep 10, 2009 7:20 pm
how hard would it be to bend the top of my shifter slightly to the general angle and put on a pistol grip handle
1987 D150
PostPosted: Thu Sep 10, 2009 7:29 pm
Howdy!
rock
'64d100
If you can find it Iwould be interested in it mine is the slip fit style but I am going to upgrade to the bolt on style when I have a little extra cash I talked withthe folks at Brewer's and decided that that was the way to go.
1987 D150
PostPosted: Sat Oct 03, 2009 3:00 pm
Pistol Grip shifter from Brewers (model 72-4B) works great in the Dart with a bench seat.
66Dart
PostPosted: Sat Oct 03, 2009 6:04 pm
nice looking set up and beautiful dart btw I may try that but I will have to have my shifter converted to the bolt on style mine is currently the slip in fit
1987 D150
