It is currently Mon Nov 30, 2026 6:14 am
PostPosted: Wed Sep 09, 2009 1:11 am
There are two bosses on the drivers side of the head. Will it be enough to attack the chains to those and lift the engine out of the car? The tranny is already pulled.
1970 Plymouth Duster
PostPosted: Wed Sep 09, 2009 6:17 am
Yes that is where you lift. The factory/dealers used just 1 with an L bracket front for engine only back for engine and trans.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Sep 09, 2009 10:56 am
Use the front hole when lifting the engine only.
Use a strap between both holes when lifting the engine with the transmission attached.
PostPosted: Wed Sep 09, 2009 12:16 pm
Perfect! Really appreciate it guys!
Robert
PostPosted: Wed Sep 09, 2009 12:45 pm
Since a few of us,ok just me,pull/install slants in vans a different lifting point is needed as every inch of head room we can get is required.Got this design out of a mid 70's Clymer/Haynes manual(back when they were good),might have even been a Chilton manual,time fogs the memory :?
PostPosted: Wed Sep 09, 2009 8:10 pm
Could you post a dimensioned sketch of the lifting bracket?
Ken
PostPosted: Wed Sep 09, 2009 8:23 pm
No problem,have to dig it out of my files in the shop,I'll scan an post it tomorrow.
PostPosted: Thu Sep 10, 2009 11:58 am
I made my own out of angle iron, and bolted it to the two bosses provided on the head. I then attached my chains on either end. It worked very well:
PostPosted: Thu Sep 10, 2009 12:11 pm
Ken here you go,if the scan isn't clear on dims let me know
Once it was built I used an old int/exh gasket to mark for stud holes. Color pic also shows steel strap from lifting plate to lower block(where trans bracket bolts).Front hole on plate is for boom hook,rear hole is for van specific holdy upper tool,if interested I can e-mail you pic and dims for that.
PostPosted: Fri Sep 11, 2009 7:41 am
Thanks for posting the sketch!
Users browsing this forum: DuckDuckGo [Bot], Rick Covalt and 6 guests
