It is currently Wed Sep 30, 2026 8:12 pm
PostPosted: Sat Sep 05, 2009 9:28 am
bigslant6fan,
The MOPAR distributor spring kit came today. I had hoped that one day someone would provide a stock spring kit.
Some how you have managed to replicate the stock springs perfectly.
The distributor spring chart you sent should be a great guide and tuning tool.
Thank you very, very much! They look great! :D :D :D
I am wishing it wasn't raining out so I could do some testing.... :cry:
PostPosted: Sat Sep 05, 2009 1:02 pm
Ted:
bigslant6fan,
bigslant6fan,
I just retrieved my kit from the mail box this clear dry Saturday. Nice, nice stuff. Thanks.
The graph accompanying the springs, shows degrees crankshaft vs. rpm. Would one plot his initial advance degrees and slide over to the right to required rpm for the mechanical advance to kick in, and use that color spring? Do I have this right?
PostPosted: Sat Sep 05, 2009 3:06 pm
What's the source of this spring kit? My reading has been hit and miss lately... did I miss something?
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Sep 05, 2009 3:26 pm
dakight,
No hit and miss, just PM "bigslant6fan" and order the kit.
Charlie has 50 kits!
Last edited by Aggressive Ted on Sat Sep 05, 2009 3:30 pm, edited 1 time in total.
 Post subject: MOPAR spring kit
PostPosted: Sat Sep 05, 2009 3:28 pm
wjajr,
Yes, that is right. Then double check with your timing light to confirm.
PostPosted: Sat Sep 05, 2009 4:05 pm
Ted,
Me quoting me:
I get it, I think:
Single color listed on graph is just primary spring; two spring colors = Primary & Secondary spring combination.
PostPosted: Sat Sep 05, 2009 4:11 pm
wjajr,
Correct.
I would only work with one spring at a time, on the primary side only.
Did you get rid of some of the clatter when you re-lashed the valves?
PostPosted: Sun Sep 06, 2009 1:00 pm
Ted:
Well, yes & no. Tightened up exhaust, but loosened the intakes some more so it is about the same. However the car idles lower around 900 with a nice lope that caused most every one that hears it to ask if I have a 340... I don't know who is more disappointed me for not having one, or the dope that cant discern the song of a six form a V8...
Still haven't played with springs yet. I was only going to change out the primary spring, just wanted to fully understand the chart.
PostPosted: Sun Sep 06, 2009 8:19 pm
I'd suggest measuring the advance slots and welding the outboard sides if it's wider than 0.400.This will limit mechanical advance to about 20 degrees total.Then you can set your idle timing to 10-12 BTC and have 32BTC at high speed.You can use acid core solder to weld the slots,but it may pound out in 20-30,000 miles because it's softer than brazing.
PostPosted: Tue Sep 08, 2009 5:33 pm
I want one.
PostPosted: Tue Sep 08, 2009 10:49 pm
PM bigslant6fan for a kit! :)
PostPosted: Wed Sep 09, 2009 4:26 pm
popcorn time
PostPosted: Sat Sep 12, 2009 5:03 am
PM sent.
PostPosted: Mon Sep 14, 2009 7:35 pm
I still want a distributor spring kit. Sent PM on 9-07-09. Please reply.
PostPosted: Fri Sep 18, 2009 9:43 am
O.K. then, never mind!!! :roll: :roll:
