It is currently Mon Apr 27, 2026 2:00 pm
PostPosted: Sat Sep 12, 2009 7:07 am
Hello, i just bought a d100 with a six in a row, and the front passanger rubber break hose was cracked so it failed inspection. I just replaced the hose, but now the pedal will hit the floor with poor stopping power, if i pump the breaks a couple times, then ill stop ok.. do i need to bleed the front break, if so how do i do this? any other suggestions? the year of the truck is 84, if that helps with front disc.
thankyou
84 D100, stock 225, 1bbl, with a glass pack!
PostPosted: Sun Sep 13, 2009 1:09 am
ahhh! you need to stop driving it and bleed all 4 brakes properly.
http://www.popularmechanics.com/automot ... 13448.html
PostPosted: Sun Sep 13, 2009 3:21 am
ditto what jester said :!:
Nothing beats a slant six
1987 D150
PostPosted: Mon Sep 14, 2009 3:11 pm
If you bleed the brakes correctly and the pedal still isn't firm, don't overlook the possibility that the MC has failed. I've seen that happen often when a MC travels much more than it has in many years.
I presume any of the seals travel through a (corroded?) region they haven't seen for a long time and it damages the seals. For that reason, I usually just replace or rebuild everything in the system (with the possibility of the hard lines) if there's any question at all about its condition. I find it saves time, money, and effort in the long run to just do it all at once and I've never regretted it.
Beware of Chinese-made copper washers that don't seal well because they're too thin.
