It is currently Tue Jan 28, 2025 2:57 pm
 Post subject: Super6'N an '80 Van
PostPosted: Wed Sep 16, 2009 5:56 pm
I have a 76-78 super 6 van for parts (Not sure). Will the linkage all swap over? I haven't had a chance to pull the dog house on the 80 to compare. It is 40 miles away.
Both are 833OD's no kickdown needed.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Wed Sep 16, 2009 6:19 pm
Good question Rug,I'm thinking it should.Dodge changed a few things body wise starting in 78 but the bellcrank/whozen socket,rods an such didn't change much until the switch over to TBI in like 88 which is cable.
There maybe some rod length issues but just bend up some new ones or,if you need cable setup for your supersix just use pedal/cable etc.from a newer TBI which is what I did for my 4brl conversion.Good luck,I'm thinkin to hang a supersix on one of my many slant vans(up to 3 now)and they're all rod throttle and the carter I've got is cable so let me know how your's goes 8)
PostPosted: Wed Sep 16, 2009 6:59 pm
I am anxious to see how this engine runs. I ported the head and polished the chamber.
I did everything for anti-reversion. I would like to gasket match the exhaust manifold just haven't had the time.
I really need to work on my Dart motor.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
