It is currently Mon Apr 27, 2026 2:42 pm
PostPosted: Wed Sep 16, 2009 8:23 pm
How do I determine my wheel size? This is for a 69, 4 door Valiant. Right now there are 195/75 14 tires on the car.
http://www.travisruse.com/wheel/image/page1.html
Thanks for the help.
Travis
PostPosted: Wed Sep 16, 2009 9:00 pm
http://www.discounttire.com/dtcs/infoBoltPatterns.dos
http://www.discounttire.com/dtcs/infoSidewall.dos
I hope either of these helps :)
66 Barracuda 225(Resto under way.)
PostPosted: Thu Sep 17, 2009 3:47 am
He wants someone to look at the photo of his wheel and tell him if it's the 14" x 4½" or a 14" x 5½" item. I'm out of practise and so can't give a reliable answer.
PostPosted: Thu Sep 17, 2009 4:03 am
Unless it's marked on the wheel, you need to measure it..............
Then subtract 1" from what you measure to get the inside measurement.
PostPosted: Thu Sep 17, 2009 10:29 am
You don't need to measure it. The difference is visually obvious in the depth of the wheel rim visible outboard of the wheel web, it's just I'm out of practise and can't trust my memory as to what is shown in his picture. (or if the tire's removed the wheel size is stamped on the outer circumference of the barrel).
PostPosted: Thu Sep 17, 2009 3:02 pm
Ok............ this is a 14" x 5.5" you can compare to yours........
PostPosted: Thu Sep 17, 2009 6:40 pm
Ed: Perfect!
Travis: Looks like you have 14" x 5½" wheels.
PostPosted: Thu Sep 17, 2009 8:07 pm
Awesome! Ed thanks for posting the photo. I really appreciate the help everyone.
Travis
