It is currently Sat Nov 21, 2026 7:56 pm
What Would you like to see most for an engine build?
Twin Turbo Slantsix 32%  32%  [ 6 ]
Twin Turbo Slantsix with Nitrous 26%  26%  [ 5 ]
198/2.2L "stroker" 42%  42%  [ 8 ]
198/2.2L "stroker" with Nitrous 0%  0%  [ 0 ]
Total votes: 19
PostPosted: Sat May 17, 2003 7:21 am
Justin, to see any REAL benefit to a smaller bearing giving less bearing drag and more HP, you'd have to go to .100 OS and buzz the motor to 9000rpm. I only want to grind a crank as much as it takes to clean it up. All the side benefits to smaller journals are so small you'd never be able to notice them on most slant six build ups.
One exception will be offset grinding the crank to the biggest OS bearing available (.040?). This will add .040 to the stroke, if you have a good rod journal to start with, and will give increase compression the same as milling .020 off the block. You'll get 2 more HP out of a near stock 225.
Cecil
PostPosted: Sat May 17, 2003 10:05 pm
Thanks Cecil,
I'm in the process of making the calls to find prices and also making my "final" list for this motor :)
more to come!
Justin
 Post subject: it's alive!
PostPosted: Mon May 19, 2003 8:35 pm
well the fresh slant runs good and it sound nasty (mean, that is).. the crank is spinning nicely :lol:
PostPosted: Tue May 20, 2003 3:09 pm
you mean it works :P :P :P
good to hear!!!
Justin
Users browsing this forum: Bing [Bot], Google [Bot], Plymouth_Ruster and 4 guests
