It is currently Sun Nov 29, 2026 2:21 pm
PostPosted: Fri Sep 18, 2009 8:32 am
My aluminum block slant six 225 that I rebuilt from the ground up runs fine but after a few minutes it blows out all the antifreeze. I put a new thermostat in it and changed the radiator cap to a 13 lb cap, no change! Any ideas?
PostPosted: Fri Sep 18, 2009 10:42 am
Some thoughts......
Sounds like you have some air pockets which are turning to steam and blowing out the water.
1. Is the heater core hooked up? Some times it takes awhile to purge out all the air.
2. Does your thermostat have a small 1/8" hole drilled in it to let some of the steam/air bubbles out? I would put the hole at the top so it will allow the air to escape......
3. Is the bottom radiator hose collapsing?
PostPosted: Fri Sep 18, 2009 1:18 pm
Last time my Dart did this (overheated within 10 minutes) it was pilot error... I had installed the thermostat backwards.
PostPosted: Fri Sep 18, 2009 2:58 pm
Yup. Check all of the above, and drill a small hole in the stat, say 1/16 to 3/32 of an inch, mounted at twelve o'clock.
Once the thermostat is properly positioned, and air can be purged from the head as you refill the system, all will be well.
PostPosted: Fri Sep 18, 2009 4:08 pm
Run without the cap to purge the air.
Hopefully it's not the head gasket.................
PostPosted: Fri Sep 18, 2009 10:09 pm
... after a few minutes it blows out all the antifreeze. I put a new thermostat in it and changed the radiator cap to a 13 lb cap...
It may be too obvious to suggest, but when was the last time you know for sure that the radiator functioned? When they get old, they can flow lots of water but transfer very little heat.
I finally replaced the 40+ yr old unit in my Valiant even though it *looked* fine, and the cooling capacity change was like night and day. Literally.
- Erik
PostPosted: Sat Sep 19, 2009 12:09 am
Kinda thinking blown head gasket also..any air in the system should have purged itself out by now.
PostPosted: Sat Sep 19, 2009 4:45 am
You did use the correct head gasket, right? There is a difference in the gaskets for the aluminum and cast iron engines.
Users browsing this forum: Google [Bot] and 8 guests
