It is currently Sat Nov 21, 2026 1:08 am
 Post subject: Hard Shift
PostPosted: Sun Sep 20, 2009 4:48 pm
When I shift my transmission into gear, there is a loud metallic clunk and the vehicle jumps forward or backwards. What could be the problem? Thanks
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Sun Sep 20, 2009 5:38 pm
What speed is your engine running when you notice this?
PostPosted: Sun Sep 20, 2009 5:54 pm
Not even moving...when shifting from park or neutral.
PostPosted: Sun Sep 20, 2009 6:19 pm
Re-read my question to you and try answering again, please.
What RPM is the engine at(hopefully at idle?), not vehicle speed.
EDIT: Jinx dan!
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Sun Sep 20, 2009 7:15 pm
Sorry...500rpm, the stated idle speed in the factory service manual.
PostPosted: Sun Sep 20, 2009 7:25 pm
I was thinking maybe we were talking about a situation where the engine was running on the fast-idle cam after a cold start; under that condition a hard engagement is normal. But if you're getting a lurch/bang even when the engine's warm, at that very low idle speed, then something's the matter — I'm thinking a possible problem in your torque converter.
PostPosted: Tue Sep 22, 2009 2:08 pm
I pulled the driveshaft out and the bang went away and I also noticed that the transmission yoke spins in neutral. Is this normal?
