It is currently Tue Nov 17, 2026 4:37 am
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Fri Sep 18, 2009 11:16 pm
H'mm. How d'you reckon it? Most '73 and '74 slant-6 passenger car applications used the #3755042/043 distributor, and there are some 1976 distributors, '714 and '082 for example, that have good curves built in from the factory.
It depends on which one he used for the retrofit. They maybe great for a car but may need to be more finely tuned for his truck and to match the gear ratio.
PostPosted: Sat Sep 19, 2009 8:56 am
When I get the carb rebuilt I will tackle the distributor.I plan on removing it and checking #s on vacuum can and distributor.Also timing it to TDC and checking timing at 500rpm intervals until the centrifugal advance stops advancing[vacuum advance plugged of course].Then applying vacuum with a hand pump to see advance at different amounts of vacuum.The readings I get on the centrifugal I will subtract from vacuum readings to get actual vacuum difference.Well thats the plan any variables I missed?
PostPosted: Mon Sep 21, 2009 5:05 pm
Got the carb apart.Main jet is stamped 671.Measures between .060 and .065.The idle bleeds were clear and open.The power valve has holes measuring .105 drilled across it.The power valve is stamped 3.There seems to be some room to open up the venturi.[url]http://s658.photobucket.com/albums/uu310/oldblue1982/? If I open up the venturi would it help or hurt?
PostPosted: Mon Sep 21, 2009 5:43 pm
Are you quite sure it's not stamped "621" rather than "671"?
PostPosted: Mon Sep 21, 2009 8:34 pm
Here is the main jet
PostPosted: Mon Sep 21, 2009 8:45 pm
This is the area I am thinking of porting
PostPosted: Mon Sep 21, 2009 9:45 pm
oldblue,
That is a huge jet!.......It is a close tolerance #67. I haven't even tried one that big drag racing. #64 is the biggest I have tried so far on the street......No wonder your plugs look dark.
You must be leaving quite a sooty trail when you first crank it up in the morning!
You got a picture that you could post of the bottom side of the air horn (top half of the carb)? Does it need to be ported out too? or is it already done?
My 1945's are all in boxes....
PostPosted: Mon Sep 21, 2009 10:09 pm
Air horn is opened already.The scribed mark [smile]on picture is where the air horn fits.The main jet is under .065 but above .060.Plugs air clean not black at all.The power valve is stamped 3.I take it that means 3" vacuum engagement.The idle air holes are just to the left of the smile.
PostPosted: Tue Sep 22, 2009 11:26 am
Ported the body.Main jet at .059 now.Starting assembly next.Thought I would show the porting.
Image]
PostPosted: Tue Sep 22, 2009 4:24 pm
I got it back on and it runs.Idle at 600 rpm in gear.Idle screw out 1 3/4 turns.Fires right up hot,just bump the key.Won't know the mileage for awhile but feels crisper.The main is a .059 or a #59.Thanks for all you responses.
PostPosted: Tue Sep 22, 2009 11:02 pm
Looks great!
You will get better mileage with the crisper jetting.
I like mine to be crisp feeling and responsive too!
Glad to help. :)
PostPosted: Thu Oct 08, 2009 8:15 am
I need some information about the power valve in 1945.
The instructions in the carburetor kit say following: The power valve spring that came in the kit is compatible with 74-75 carburetors only. If you have a 76-on carb, you should use the old spring over.
What's the difference between the power valve springs?
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
