It is currently Sun Nov 29, 2026 6:41 pm
 Post subject: Triple carbs?
PostPosted: Wed Sep 23, 2009 8:52 am
I have been thinking about running-building a triple carb intake for my slant and wondered if anyone has done this. I have 3 1945 carbs and an extra set of flanges laying around. would be installed on a 225 10.5-1 comp, erson 270 cam, p&p head. any ideas?
Image75 dart custom, 225, >10.5-1, hurricane, 500holley, erson cam, 904, 8.8 ford 3.55 or 3.91 aussielocked, 17" steelies, and much more.
PostPosted: Wed Sep 23, 2009 9:14 am
Never seen a triple downdraught intake before (although I'm sure they've been done, Mr. Mueller comes to mind,) only sidedraught with DCOE carbs. I think ExnerGeek has run these on hid drag car, a few others.
-James
PostPosted: Wed Sep 23, 2009 1:08 pm
does anyone know the cfm of a 1945? any ideas on runner length? figure i could run the factory kickdown off of center carb.
PostPosted: Wed Sep 23, 2009 6:41 pm
It'll look great, and it might go great, but you'll probably have to take that "21mpg and counting" line out of your signature after you install three carbs.
:D :D :D
- Mac
PostPosted: Thu Sep 24, 2009 3:37 am
Car Model: '23 T-bucket
I regularly visit an old car/hot rod forum, and the same or similar question comes up from time-to-time. Those guys typically tell folks to run the carbs with a progressive linkage system, not all three carbs opening and closing the same amount all the time. Run the engine off that center carb at part throttle and cruise, and set the linkage up to crack the "secondaries" at about half peddle stroke. This way, you should get the best of both worlds.....good fuel economy, and lots of fuel/air when you want it.
Roger
PostPosted: Thu Sep 24, 2009 7:04 am
Roger
I guess that depends if you make the manifold a 3X2 or 1 large plenum.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Sep 24, 2009 9:29 am
Cfm rating of different carbs.http://cars.rasoenterprises.com/Carburetion.htm
PostPosted: Thu Sep 24, 2009 9:59 am
I will most likely be running a true 3x2 with 3 1945 carbs. I will be spinning the motor to 6300 rpm. Dont worry " 21 mpg and counting" will soon be replaced by 1/4 mile times. :D :shock: :shock: :D Still unsure of runner length. any ideas???
PostPosted: Thu Sep 24, 2009 11:05 am
I have not played with this yet,but here you go.http://www.bgsoflex.com/intakeln.html
 Post subject: runner length
PostPosted: Sun Sep 27, 2009 6:11 am
The rule of thumb for runner length is 90 divided by rpm in thousands. This is for to the plenum and even with 3x2 you will have to have a small plenum under the carb.
With Webers or individual EFI bodies (which can be tuned through and have no plenum or box underneath )you can include them in the total tuned length but with a plenum you tune to the plenum. I have been using this formula for many years and have found no need for another
So for 6000RPM you get 90/6=15 inches. That length by the way is to the middle of the intake valve so you must include the cylinder intake port length in your calculations
Don
Don
PostPosted: Mon Sep 28, 2009 8:52 pm
thanks guys you have been a big help. now its time to start building.
Users browsing this forum: Bing [Bot], slantzilla and 8 guests
