It is currently Sun Nov 29, 2026 4:08 pm
 Post subject: offy 4bbl manifold
PostPosted: Fri Sep 25, 2009 6:33 am
I was just wondering, If I want to put a offy 4bbl manifold on my slant 6... do I need another exhaust manifold aswell, or is the offy compatible to the original 170 exh. manifold?
... or is a 4bbl manifold just retarded on a 170?
PostPosted: Fri Sep 25, 2009 4:04 pm
You are ok with the stock exh manifold. I would however do some head work and cam the engine. Also would go to 2 1/4 exhaust.
Frank
PS I have an Offy for sale if you need one
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Sep 25, 2009 6:32 pm
Frank,
You know where I can get the mounting plate for the carb? I have tried posting on parts wanted.
PostPosted: Sat Sep 26, 2009 5:43 am
Ted
I have heard its still available from Offy for about 31 bucks. I only buy and sell with the adapter plate so I havent needed one. Although I will need one for my new Aussie Manifold.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: adapter plate
PostPosted: Sun Sep 27, 2009 6:00 am
Make a new plate from a four hole 1 inch spacer. Turn the carb sideways with throttle shaft parallel to the engine. it will run so miuch better you will wonder why it wasnt built that way. Idle will improve dramatically and idle air screws will be responsive to even a slight adjustment. Engine will run smoother at all part throttle settings. A MAJOR improvement to say the least.
The mode to the four hole spacer to fit the manifold takes about 10 minutes including countersinking the holes so counter sunk or as I use allen head screws can be used. A paper pattern with get you the drill spots. A minor clean up where the carb holes meet will make it perfect although if I do it again I wil remove the holes in the manifold proper as they are with the 1 inch spacer redundant.
Don
Pic of mine on the Seniordragster website. Feels really strong in testng too. Pulls very hard
Don
PostPosted: Mon Sep 28, 2009 6:25 am
Hey Don I totally agree. Putting the carb sideways is the best. I do ALL mine like that.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 7 guests
