It is currently Sat Apr 25, 2026 4:39 am
PostPosted: Mon Sep 28, 2009 11:57 am
Ok, the front brake hoses on an '81 D150 pickup are attached to the calipers with a banjo bolt through a block fitting and this block can be fitted with the hose pipe facing down (as pictured) or with the fitting rotated 90º and the pipe facing inward. I replaced the pass. side a few months ago with the pipe facing downward as pictured and I assume I just put it back on the way it came off (but now, not sure).
I am now doing the driver's side and before taking it off, I find the fitting attached with the pipe facing inward. Now I am wondering if a PO got one side put on wrong in the past, or if I spaced it and put the pass. side on wrong? I tried looking in a Haynes, but it didn't have any photo's showing the fitting.
Can anyone shed any light?
<img src="http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=387" border="0">
'81 D150 with "Lean Burn"
