It is currently Mon Jun 15, 2026 8:47 pm
 Post subject: Timimg
PostPosted: Thu Oct 01, 2009 11:23 am
Now that I have spark and the slant 6 is running , I want to time it. I have adjusted the valves set the dwell but I am unable to get it timed to the exact spec. I can come close but not exact. If I remove the distributor and rotate it clockwise a tooth I still can not get it exact. If I remove the distributor and rotate counter clockwise same problem. I can get it within 10-15 degrees either BTDC or ATDC but not to 2.5 -5 BTDC as required. The timing mark is not wandering.
Thank you,
Otto
PostPosted: Thu Oct 01, 2009 12:29 pm
there is a bolt on bottom of distributor that allows more adjustment....
keep on roddin'
PostPosted: Thu Oct 01, 2009 4:57 pm
Thanks for the reply. Are you saying there is an addittional bolt besides the one on the block?
Thanks,
Otto
PostPosted: Thu Oct 01, 2009 5:01 pm
Thanks,
Otto
Yes.
PostPosted: Thu Oct 01, 2009 5:22 pm
I forgot to disconnect the Vacuum advance. I will try again tomorrow.
PostPosted: Sat Oct 03, 2009 6:29 am
HA done that once or twice..did it change when un pluged..I find some times it dont..
Its so nice out side, I think I'll go lay under my car..
PostPosted: Sat Oct 03, 2009 10:49 am
Herr Otto, here is a picture of the bolt on the bottom of the distributor:
PostPosted: Sat Oct 03, 2009 11:05 am
I've never found a difference in the timing when plugged or unplugged.
PostPosted: Sat Oct 03, 2009 1:48 pm
ESP47,
Then your vacuum advance diaphragm is ruptured or stuck! Get a new one so you can get better mileage and engine performance. Your motor must be pretty sluggish and flat, not punchy......When my pod kicks in it feels like a sling shot!
PostPosted: Sat Oct 03, 2009 2:32 pm
The distributor is hooked to ported vacuum; at idle it *should* see zero vacuum and have no effect on timing. However, it is best practice to remove and plug the distributor vacuum line while setting the initial timing.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Oct 03, 2009 2:36 pm
Disconnected the Vacuum advance and plugged and also found the bolt beneath the distributor and loosened it up a bit. I was able to set the timing now . Thank you all for your help.
Otto
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
