It is currently Tue Nov 17, 2026 1:07 pm
PostPosted: Sun Oct 04, 2009 3:42 pm
so i have a 225/6 which had a no spark problem which i fixed but in doing so i removed the distributor to replace the points. now the engine fires but is not firing correctly. it almost seems as if the engine is firing on the wrong part of the compression. also turning the distributor causes no change. a walkthrough on how to correctly place a distributor and what position the 1st piston should be at (i'm guessing Top dead center) would be very helpful. thanks
-Darryle
PostPosted: Sun Oct 04, 2009 4:09 pm
Hello and welcome. See this thread for instructions on how to retime the distributor.
PostPosted: Sun Oct 04, 2009 4:18 pm
This may also help.
PostPosted: Sun Oct 04, 2009 6:23 pm
REED that link was all the help i needed i still need to do a little fine tuning and repalce the intake/exhaust gasket to fix a vacuum leak but the engine started right up. thanks!
-Darryle
PostPosted: Sun Oct 04, 2009 6:50 pm
:D Happy to help and happy to hear you got it running. Cheers!
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 6 guests
