It is currently Sat May 09, 2026 4:41 am
 Post subject: Fuel Pressure Regulator
PostPosted: Thu Oct 08, 2009 11:36 am
I'm installing a regulator so that I can use a Holley 5200 carb. Where does it go in the fuel line? I would assume, before the filter.
If I'm reducing the pressure at the carb, am I increasing the pressure somewhere else? Will this cause a leak, or rupture the pump diaphragm?
Do I need a "fuel tank return"? This is an inexpensive Mr. Gasket regulator, so there is no fitting for a return.
What else do I need to know?
I especially would like to hear from people who have successfully used the Holley 5200 and Weber carburetors.
PostPosted: Thu Oct 08, 2009 11:59 am
H'mm. What fuel pressure are you trying to achieve? I have found FPRs to cause more problems than they solve on systems with mechanical fuel pumps.
PostPosted: Thu Oct 08, 2009 2:40 pm
3.5-4.5 PSI seems to be the consensus. Would I be better off with an electric fuel pump?
With the stock setup, the engine acts and smells like it's getting too much gas.
PostPosted: Thu Oct 08, 2009 2:58 pm
sounds like a carb rebuild is what you need more then a pressure regulator. or maybe just an adjustment to the fuel air mixture
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Thu Oct 08, 2009 3:26 pm
Then you're in luck, because the stock ordinary unmodified un"regulated" slant-6 fuel pump produces 3.5 to 5 psi.
Even bigger pain in the rear than a FPR with a carburetor.
Sounds like the carb is faulty and/or improperly adjusted. Lowering the fuel pressure would be a band-aid; I think I would turn my efforts and attention to the carburetor itself before I'd add extra parts to the fuel system, though if you want to be precise you can put a fuel pressure gauge in the line between pump and carb and see what you read.
One "extra part" that would be a good idea to add would be a vapour-bleed fuel filter (Wix 33054 or NAPA Gold 3054, Purolator F20030). In addition to the inlet and outlet nipples, it has a 3rd nipple which is a vapour return. It has a 0.060" orifice and takes a ¼" hose, which you must route safely back to the fuel tank (a hassle, but not impossible). This helps alleviate high fuel pressure that develops between the pump and carb after shutdown.
PostPosted: Thu Oct 08, 2009 10:48 pm
I used a Holley 5200 carb with a stock mechanical fuel pump. No leakage or float sinking problems at all.
PostPosted: Fri Oct 09, 2009 12:25 pm
"I used a Holley 5200 carb with a stock mechanical fuel pump. No leakage or float sinking problems at all."
A-ha! That's the answer I was looking for. I will concentrate my investigation elsewhere.
I've got 5 of these carbs, all carefully rebuilt. All have serious vacuum leaks at the throttle shaft, which, I am told, is impossible.
My current unit was purchased as NOS, and it, too, had a vacuum leak. I had it re-bushed. The carburetor expert thought I was a fool, but it made a big difference.
I've spent a lot of time and effort rebuilding these carburetors to the specs. I think the next step is to take a hard look at the needle and seat. I've already replaced it once.
Thank you for your input, everyone. You may have saved me some trouble. I know that there are several members of this forum that use this carb, and I would love to hear their perspectives.
Users browsing this forum: Google [Bot] and 9 guests
