It is currently Mon Oct 12, 2026 8:37 am
PostPosted: Fri Oct 09, 2009 1:34 pm
OK, so I began taking off things like the water pump, thermostat housing, manifolds etc, in prep for painting my engine/adding dutras.
I take off the thermostat housing and go to shove a rag in the hole to keep out debris and there's a stiff wire like a coat hanger in the block (but it's thinner and has no kinks).
What gives? Is it from the casting sand? I was going to pull it out and 99% of my brain says it doesn't belong (along with experience) but I wanted to ask about it before I did.
Help.
PostPosted: Fri Oct 09, 2009 1:42 pm
Yep, it's left over from the casting. Grab it and yank it out so it won't turn into rust flakes that clog up your radiator.
PostPosted: Fri Oct 09, 2009 1:44 pm
Thanks Dan.
PostPosted: Fri Oct 09, 2009 3:54 pm
There were 3 or 4 of them in my head when I started working on it.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Oct 11, 2009 8:48 am
I saw one of those too when I changed my water pump. Mine was stuck pretty hard, so I left it alone. Figured if it had been in there a couple decades not hurting anything, it wouldn't bother me too much. Had no idea what it was.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 7 guests
