It is currently Thu Nov 12, 2026 8:20 am
PostPosted: Sun Oct 11, 2009 11:01 am
The other night I noticed that when I stepped on the brake, my turn signals quit working. So I got out to check, and I had no rear lights at all! the brake lights work, but only if the lights are off. sometimes if you step on the brake with the lights off, all the marker lights come on but really dim. If you turn the turn signals on, both tail lights and rear marker lights flash, but are really dim. We tried replacing the light sw, turn sig sw, and the flasher, nothing. We tried to trace the turn sig wires down, and no matter what direction its on, both wires flash hot. The front lights and turn signals work perfectly. Any ideas?
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Sun Oct 11, 2009 11:48 am
My boss had the same problem. Faulty ground was his cause. Worth a look.
PostPosted: Sun Oct 11, 2009 4:06 pm
Yep, that was it! Thanks :D
